Confused about: g(x) = (x - 1)^2
  • Thread starter Googl
  • Tags
    Confused
In summary, the conversation discusses confusion with understanding the example provided in a book on sketching curves. The example involves using functions f(x) and g(x) to sketch curves with equations y=f(x+1) and g(x+1). The expert explains that functions should be thought of as rules that associate a member of a set with each member of a domain. They also provide a new example with a more complicated function to help clarify the concept.
Googl
111
I am revising on sketching curves. But I am very confused about the following even though I have become very good at sketching graphs.
An example from the book is:
Given that:
i) f(x) = x^3
ii) g(x) = x(x - 2)
Sketch the curves with equation y=f(x + 1) and g(x +1)
I don't understand the example that the book provides. Not because I don't know how to sketch the curve but the use of g(x) is what I don't understand. Somewhere in the example workout it says:
g(x) = (x - 1)^2
so -> g(x) = f(x - 2)
Also
h(x) = x^2 + 2
so -> h(x) = f(x) + 2
Please help as I would like to finish this chapter sooner. The use of h(x) and g(x) is what I don't understand. I will also appreciate any links that you may provide.
Thanks.
Mathematics news on Phys.org
Given that:
i) f(x) = x^3
ii) g(x) = x(x - 2)
I assume that "g(x+1)" really means y=g(x+1). Just use the definition of g (given in ii) to rewrite the right-hand side.
Googl said:
g(x) = (x - 1)^2
There's something missing here. This is clearly not the same g as before, so it's probably a different f as well. I can't comment unless you tell me what f is.
Googl said:
Also
h(x) = x^2 + 2
Same thing here. What is f?
Edit: Some general comments about functions: Students often think of functions as relationships between variables, but it's better to think of a function as a rule that associates a member of a set (called the function's codomain) with each member of a set (called the function's domain). If f is a function, f(x) denotes the member of the codomain that f associates with x. f(x) is called the value of f at x. We also say that f takes x to f(x).
For example, if f is defined by ##f(x)=x^2## for all real numbers x, then f(3)=9. Here f is the function that takes every number to its square, and its value at 3 is 9. Also, the value of f at x+1 is f(x+1), which by definition of f is =(x+1)2. Note that f(x+1) isn't a function. It's a member of the codomain of f. However, without knowledge of the value of x, we can't know which one it is.
We can also talk about the function that takes x to f(x+1). If we define g(x)=f(x+1) for all x such that x+1 is in the domain of f, then we have defined a function g. People often refer to that function as "f(x+1)", but if you want to be accurate, you need to refer to it as "the function that takes x to f(x+1)", or something like that.
Thanks for the reply. It is beginning to make sense now.
Hey. This is the first time I've ever helped someone on this site. I'll try my best.
Googl said:
Given that:
i) f(x) = x^3
ii) g(x) = x(x - 2)
So is the problem here trying to figure out what these two new f's and g's are supposed to be?
When you have f(x) = (x)^3, think of the left hand side as saying you are making a rule labelled f on the variable also called your input, or argument, (x). This is denoted f(x). The right hand side says specifically what that rule involving your input is. (x)^3.
By the way, we could have rules that do a lot more things, like cubing x, then adding another 6x to it, and perhaps adding a constant to it all like 5, then perhaps dividing everything by 2. This would look like f(x) = (x^3 + 6x + 5)/2 . Try to understand this maybe after if it doesn't make sense now.
Continuing on though...
y = f(x+1) is saying take your original rule that you were given on (x) ( the rule is to cube (x) right? ), and just do the same rule to a new the input, (x+1), and it also is saying that were calling this new thing y. So in this case we just slap on ^3 to the input (x+1).
I'm not really sure what you mean by the other functions they are giving you either.
Hope this helped.
Dear student,
I understand your confusion with the example provided in the book. The use of g(x) and h(x) in the given equations may seem confusing at first, but it is actually a common notation used in mathematics to represent functions.
In the given example, f(x) is a function that maps a value of x to its cube, while g(x) is a function that maps a value of x to its product with (x-2). Similarly, h(x) maps a value of x to its square plus 2.
Now, when we have to sketch the curves for y=f(x+1) and g(x+1), it simply means that we have to shift the graph of f(x) and g(x) one unit to the left, as we are replacing x with (x+1) in the equations. This will result in a new graph with the same shape but shifted to the left.
As for the use of f(x-2) and f(x)+2, it is just another way of representing a shift in the graph. In the first case, the graph of f(x) is shifted two units to the right, while in the second case, it is shifted two units upwards.
I would suggest practicing more with these types of equations to get a better understanding. You can also refer to online resources or textbooks on functions and graphing for further clarification. I hope this helps. Good luck with your studies!
FAQ: Confused about: g(x) = (x - 1)^2
1. What is the equation for g(x)?
The equation for g(x) is g(x) = (x - 1)^2. This means that the function g(x) takes the value of x, subtracts 1, and then squares the result.
2. How do I graph g(x)?
To graph g(x), you can plot points on a coordinate plane by choosing a value for x, plugging it into the equation, and then plotting the resulting y-value. You can also use a graphing calculator or software to easily graph the function.
3. What does the (x - 1)^2 mean in the equation?
The (x - 1)^2 is an exponent, which means it tells us to multiply the number (x - 1) by itself. In this case, it means to square the expression (x - 1).
4. What is the vertex of the graph of g(x)?
The vertex of a parabola in the form y = a(x - h)^2 + k is (h,k). In the equation g(x) = (x - 1)^2, the vertex is at (1,0).
5. How do I find the domain and range of g(x)?
The domain of g(x) is all real numbers, as there are no restrictions on the values of x that can be plugged into the equation. The range of g(x) is all non-negative real numbers, as the squared term will always result in a positive value.
