I Confused about identity for product of cosines into a sum of cosines
The discussion focuses on the identity relating the product of cosines to a sum of cosines, emphasizing the repeated application of the two-term product rule. It illustrates how to express the product of multiple cosine terms, such as cos(a)cos(b)cos(c), as a sum of cosine terms by systematically applying the product rule. The process involves distributing terms and recognizing the symmetry in cosine functions, leading to a general formula for k terms. The final expression showcases the relationship between the number of terms and the resulting sum, highlighting the even nature of the cosine function. This explanation clarifies the confusion surrounding the application of these identities in mathematical contexts.
swampwiz
What I mean is the way that a product of cosines in which the angles increment the same amount is equal, with some extra terms, of the sum of the cosines.
It is discussed here:
https://math.stackexchange.com/ques...sines-be-rewritten-as-a-finite-sum-of-cosines
But I have no idea how this summation entity is applied.
jk + 1 ∈{ +1 , -1 }
I have been trying to search for a good explanation of this, but most of the time all I get is the stupid identity for the product of a pair of cosines.
Mathematics news on Phys.org
I don't know what you mean by "the way this summation entity is applied", but this is just repeated application of the two term product rule. For example
$$\cos(a)\cos(b)\cos(c) = \frac{1}{2}\left(\cos(a+b)+\cos(a-b)\right)\cos(c)$$
Using the product rule on a and b. Then you can distribute the ##\cos(c)##, and apply the product rule to that and ##a+b##, and that with ##a-b## to get
$$\frac{1}{4}\left( \cos(a+b+c)+\cos(a+b-c)+\cos(a-b+c)+\cos(a-b-c)\right)$$
This is just summing every way to pick a sign for b and c, so you can rewrite this as
$$\frac{1}{4} \sum \cos(a\pm b \pm c)$$
Which I think is effectively what is being written in that post. If you had k terms, you would just make that 4 a ##2^{k-1}## and add more ##\pm## terms.
There are eight ways to pick a sign for each of a,b and c, and half of them show up here. The other half are exactly negative of one of the ones that we wrote down, and cosine is an even function, so you could just include them and divide by another factor of two to get
$$\frac{1}{8} \sum \cos( \pm a \pm b \pm c)$$
And similar for if you have more terms.
Hopefully this helps a bit.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
