Confused about Newton's 3rd law
In summary, the conversation discusses the use of Newton's 3rd law in a situation where a person steps horizontally out of a skyscraper with zero vertical velocity. The conversation explains that there is a force pair between the faller and the air, and the force of the air on the faller is equal to and opposite to the force of the faller on the air. The conversation also mentions that until the faller reaches terminal velocity, the downwards force of gravity is greater than the upwards force of air resistance, causing the faller to accelerate downwards. However, at terminal velocity, the two forces balance and the faller continues to move down at a constant speed. The conversation also clarifies that the force of the faller on the air
dyn
773
61
Hi.
I am confused about the use of Newton's 3rd law in the following situation. If someone steps horizontally out of a skyscraper with zero vertical velocity. Then obviously they fall downwards. But if i apply Newton's 3rd law ; persons weight act downwards on the air so doesn't the air apply an equal force on the person acting upwards resulting in the person basically remaining stationary in the vertical direction ; ie. just "floating " there. Where am i going wrong ?
Thanks
Likes Delta2
There is a force pair between the faller and the air. The upwards force of the air on the faller is equal to and opposite to the force of the faller on the air.
There is a force pair from gravity between the faller and the earth. The downwards force of gravity on the faller is equal to and opposite to the upwards force of gravity on the earth.
Until the faller reaches terminal velocity the downwards force of gravity is greater than the upwards force of air resistance so the faller accelerates downwards. Eventually the faller reaches terminal velocity and the two forces balance - but acceleration is changing speed so no further acceleration means that the faller continues to move down at a constant speed.
Likes DrClaude and Delta2
The person’s weight acts downwards on the person. The weight is a gravitational interaction with the earth, the air is not involved at all. The third law pair for the weight is an equal and opposite gravitational force from the person pulling up on the earth.
The interaction with the air is the air resistance or drag. The air exerts drag upwards on the person and the person exerts an equal and opposite force on the air.
Is the force of the faller on the air the same as the downwards force of gravity on the faller ?
Only at terminal velocity. However, even then they do not form a 3rd law pair.
Likes dyn
If I consider a free body diagram of the person. At t=0 when the person has no vertical velocity does the diagram just have bodyweight acting downwards as the only force ? As the person falls does the diagram have weight acting downwards and air resistance acting upwards ? But at no point are these 2 forces a 3rd law pair ?
Have I got this all correct ?
Thanks
Likes Dale
Thanks for replying. Before terminal velocity what is the force of the faller on the air if it is not the same as the person's weight ?
It is some fairly complicated function of the speed. Often something of the form ##F=Kv^a## with ##K## and ##a## constants determined by wind tunnel measurements will be a pretty good approximation.
Likes dyn
Thanks to both of you for your help
Likes Dale
It is important not to confuse the notion of Third Law Pairs with Equilibrium. For a rocket in space, there is a third law pair in the force of ship on the mass of ejected material and an equal force of the material on the ship. In that situation, there is no equilibrium and the ship accelerates (without limit). The same situation in air will have two pairs and an equilibrium situation can arise at terminal velocity.
Likes Dale
I do understand the confusion people get into over the Third Law, where it seems impossible for an object to move. But it appears to me that an object moving at any speed in a fluid exerts a force on its molecules, and the molecules exert an equal force, or reaction, on the object? This seems to be Third Law, just like lab experiments using dynamics trolleys.
There is; those forces form a third-law pair. That's been stated several times in posts further up in this thread.
However, there is no particular reason why the force of the air on the object should be equal and opposite to the force of gravity on the object - those aren't a third law pair, clearly because they're both acting on the same thing. All we can say is that if those forces do happen to be the same, the net force on the object will be zero so the object will not change its speed.
Thank you for that clarification.
For an object moving through a fluid (or over a friction surface) there is just a single third law pair. This force pair is due to friction and can transfer energy both to the fluid / surface and to the object. This is not an equilibrium situation but N3 (present in all situations) has nothing to do with that.
A net force of zero doesn't imply a velocity of zero. It implies an acceleration of zero.
Likes sophiecentaur
I did state that the person started off with no velocity in the vertical direction which would mean no net force would remain at a velocity of zero
But there is a net force when the person start outs: the upwards force of air resistance is zero but the downwards force of gravity is not.
Thus the person accelerates downwards while the speed and air resistance both increase. Only when the speed has increased enough that the air resistance is as strong as the gravitational force is there no net force.
Likes dyn
don't forget buoyancy… that's an upward force acting on the body falling equal to the weight of the air it displaced.
True, but that's quite small relative to weight in most cases.
yes, in most cases.. but still 1.2kg per cubic meter certainly not 0. :)
The problem with introducing more and more fine details is that we can lose the basic picture. Before moving into 'practical' situations we need to consider the very simplest situations.
But we're talking about this case. The gravitational force exerted on a human is large compared to the buoyant force. If you want to worry about such details take the effect of Earth's spin into account, that effect is still small enough to ignore but larger than the effect of buoyancy.
Related to Confused about Newton's 3rd law
1. What is Newton's 3rd law?
Newton's 3rd law states that for every action, there is an equal and opposite reaction. This means that whenever an object exerts a force on another object, the second object exerts an equal and opposite force back on the first object.
2. How does Newton's 3rd law apply to everyday life?
Newton's 3rd law can be seen in many everyday situations, such as when you push against a wall, the wall pushes back on you with an equal force. It also explains how rockets are able to launch into space by pushing against the ground with a force, causing the ground to push back and propel the rocket forward.
3. Can Newton's 3rd law be violated?
No, Newton's 3rd law is a fundamental law of physics and cannot be violated. It is a fundamental principle that governs the motion of objects and has been proven through countless experiments and observations.
4. How does Newton's 3rd law relate to momentum?
Newton's 3rd law is closely related to the concept of momentum. When two objects interact, the forces they exert on each other are equal and opposite, but their momentum can be different. This is because momentum takes into account not only the force applied, but also the mass and velocity of the object.
5. Can you give an example of Newton's 3rd law in action?
One example of Newton's 3rd law in action is when a person jumps off a diving board. As they push down on the diving board, the board exerts an equal and opposite force on them, propelling them into the air. Another example is when a person walks, their feet push against the ground, and the ground pushes back, allowing them to move forward.
  • Mechanics
  • Classical Physics
