Confused about Shared Eigenstates
In summary, [A,B]=0, [A,C]=0, but [B,C] not equal to 0. This means that the observables A, B, and C share a complete set of eigenstates, but do not necessarily share the same eigenstates. This can be seen in the example of the total squared angular momentum L^2 and the axial angular momenta Lx and Ly, where L^2 has three distinct sets of eigenstates. In general, if two observables do not commute, their eigenstates cannot be expressed in the same basis.
TimH
56
I'm teaching myself QM and have a question about a problem in my text. (If this makes it homework, sorry to post in the wrong forum).
Basically the question is about three observables A,B,C. They obey the following rules:
So this is like the situation with the total squared angular momentum L^2 and the axial angular momenta Lx, Ly, Lz. Now I know that if the observables commute, they "share a complete set of eigenstates." So in this situation you can have eigenstates of A that are also eigenstates of B or C, but not both at the same time [yes?]. So you can't have a single quantum state that is an eigenstate of all three [yes?]. Now the question asks about the effects of these relations on sequential measurements of the observables. If you start in an A eigenstate, and measure B or C, could the state be left unchanged since they both "contribute" eigenstates to A? If you start in B or C and measure the other, will you get an even spread across the available eigenstates since they don't commute?
Or, am I drifting hopelessly in Hilbert Space??
starting with an A's eigenstate and measuring B and C will never change the eigenstate, since the state is an eigenstate of B and C as well (as you pointed out) therefore has a definite eigenvalue (which will be measured with 100% probabillity).
But the eigenstates of B are not eigenstates of C (again, as you pointed out)- that doesn't necesarilly means that an eigenstate of B is uniformly superpositioned from eigenstates of C. I mean, an eigenstate of B can be much more closer to one eigenstate of C and not the other. F.e.:
[tex]|B_{1}>=\frac{\sqrt{3}}{2}|C_{1}>+\frac{1}{2}|C_{2}>[/tex]
Perhaps the commutation property [A,B]=0,[B,C]=0 does tell that its spread uniformly, but it's not observed easily. In the general case, there is no restriction on how eigenstates are expressed in terms of other operator's eigenstates.
Okay, thank you for that. I wondered if [B,C] not equaling zero made it a straight 50-50 coin flip or not.
Now I'm definitely a beginner at QM, I'm trying to get the overall structure (I'm reading a good text, Essential Quantum Mechanics by Bowman). So in the above situation A's eigenstates (which are e.g. just eigenvectors in a matrix representation), form a complete set that spans the space (since A is an observable=Hermitian). And these are the same as B's and C', since it commutes with them. But then how can B's not be C's? I'm probably missing something basic...
I believe commutation being zero only says that the two observables may share eigenstates. I have never seen a proof that they must share eigenstates or that their eigenstates must be the same. If two observables don't commute, then they literally cannot share eigenstates.
Again, just because I've never seen a proof that commutative observables must share eigenstates, doesn't mean that no such proof exists. I may be wrong on this.
Okay, my text says "If F,G share a complete set of eigenstates, then [F,G] vanishes," where "complete set" means a set of vectors that are linearly independent and span the space (i.e. a basis). I thought that since observables are Hermitian and therefore have a complete set, there was just one such complete set for each observable (i.e. its eigenvectors in the matrix representation). Now with angular momentum for example, Lz and L^2 commute, and therefore share eigenstates. But L^2 also has eigenstates with Lx and Ly. So its like L^2 has three distinct sets of eigenstates. So are these sets all complete?
Well, it's certainly true that "If F,G share a complete set of eigenstates, then [F,G] vanishes"; however, does your book mention anything to the converse? "If [F,G] vanishes, then F,G share a complete set of eigenstates"?
Yes, but it is probably more correct to say that L^2 has a complete set of eigenstates that can be expressed in the basis of one of the other 3 operators, say Lz. The eigenstates of the remaining operators (Lx & y), can then be expressed as linear combinations in the Lz eigenbasis. Each of these linear combinations is of course also an eigenstate of L2, however, they are not *new* eigenstates ... they are degenerate states that are non-orthogonal to the Lz basis by definition, since they are expressed as linear combinations of these states.
Thus, just as in the Stern-Gerlach experiment, you are free to choose one spatial axis to define eigenstates of the projection of angular momentum. If you then try to measure the projection of angular momentum on any other axis for one of these states, you will find the system in a superposition (i.e. not an eigenstate).
Related to Confused about Shared Eigenstates
1. What are shared eigenstates?
Shared eigenstates are a concept in quantum mechanics where two or more systems share the same set of eigenstates. This means that the measurements of certain properties of the systems will give the same results. In other words, the systems have the same quantum state.
2. Why is it important to understand shared eigenstates?
Understanding shared eigenstates is important because it helps us explain and predict the behavior of complex quantum systems. It also allows us to make accurate measurements and calculations in quantum mechanics.
3. How do shared eigenstates differ from entangled states?
Shared eigenstates and entangled states are both concepts in quantum mechanics that involve the correlation of two or more systems. However, in shared eigenstates, the systems have the same quantum state, whereas in entangled states, the systems have a joint quantum state that cannot be described by individual states of the systems.
4. Can shared eigenstates exist in classical systems?
No, shared eigenstates are a purely quantum phenomenon and cannot exist in classical systems. In classical systems, the properties of the systems can be precisely measured and known, whereas in quantum systems, there is inherent uncertainty and the properties can only be described probabilistically.
5. How are shared eigenstates used in real-world applications?
Shared eigenstates have many practical applications, such as in quantum computation, cryptography, and sensing. They also play a crucial role in understanding and developing new technologies, such as quantum computers and quantum communication systems.
