Confused about thin-lens equation
  • Thread starter jayadds
  • Tags
    Confused
In summary, the thin-lens equation, 1/s + 1/s' = 1/f, is used to calculate the distance between an object, lens, and image based on the focal length of the lens. In a specific scenario where s = f, s' would become undefined, meaning the image would be formed at infinity with parallel light rays and an upright image if the lens is converging, or a virtual and diminished image if the lens is diverging.
jayadds
42
As you probably know, the thin-lens equation is given by:
1/s + 1/s' = 1/f where s = distance from object to lens, s' = distance from lens to image and f = focal length of lens
Now, in a particular question, I needed to find s' given that s = f. From the equation, that means s' would become undefined! Is that even possible? If so, can you please explain what that means in terms of the image (i.e. real/virtual; upright/inverted)?
Many thanks,
Science news on Phys.org
hi jayadds! :smile:
this is one of those rare cases when we're allowed to say that 1/0 is infinity
the image is "at infinity" …
in other words, the light rays come out parallel :wink:
If the lens is a converging lens then the object at the focal point is a magnifying glass with the image formed at infinity. Light rays passing into the eye (if it is used as a magnifying glass) are parallel and the eye is in its relaxed position. The image is upright and there is angular magnification.
If the lens is diverging then the image is formed at a distance of f/2 from the lens, it is virtual and diminished.
Related to Confused about thin-lens equation
1. What is the thin-lens equation?
The thin-lens equation is a formula used to calculate the relationship between the focal length, object distance, and image distance of a thin lens. It is represented as 1/f = 1/do + 1/di, where f is the focal length, do is the object distance, and di is the image distance.
2. How is the thin-lens equation derived?
The thin-lens equation is derived from the basic principles of geometric optics. It is based on the assumptions that the lens is thin and the light rays pass through the lens without being deviated. By applying these assumptions and using the laws of refraction and trigonometry, the thin-lens equation can be derived.
3. What is the significance of the thin-lens equation?
The thin-lens equation is significant because it allows us to determine the characteristics of an image formed by a thin lens. It is used in various optical instruments such as cameras, telescopes, and microscopes to calculate the focal length and image distance, which are important parameters for producing clear and magnified images.
4. Can the thin-lens equation be used for all types of lenses?
No, the thin-lens equation is only applicable to thin lenses, which have negligible thickness compared to their focal length. It cannot be used for thick lenses or lenses with complex shapes. In such cases, more advanced equations and techniques are needed to calculate the image formation.
5. How do I use the thin-lens equation in practical applications?
The thin-lens equation can be used in various practical applications, such as designing optical systems or troubleshooting problems with lenses. By plugging in the known values for focal length, object distance, or image distance, you can calculate the missing parameter and use it to make informed decisions about the system or lens in question.
  • Optics
  • Optics
