Confusing algebraic word problem
The discussion centers on the confusion surrounding an algebraic word problem involving boys mowing acres in a given number of days. Participants clarify that the initial conditions state c boys can mow a acres in b days, and when calculating for one boy, the time should be multiplied by c, resulting in bc days, not divided. The importance of keeping c, a, and b as constants throughout the problem is emphasized to avoid misunderstanding. Additionally, the conversation highlights the need for careful interpretation of the variables and how they relate to the number of workers and time taken for the task. Ultimately, the discussion aims to clarify the relationships between the variables to solve the problem accurately.
drooble122
See attached.
Trying to put word problems into algebraic symbols
I have great difficulty understanding the solution. I'll go through it line by line:
c boys can mow a acres in b days. This condition is from the problem and I understand it.
1 boy can mow a acres in bc days. Why not b/c days? After all isn't 1 boy from c/c=1?
n boys, or 1 man, can mow a acres in bc/n days. Why suddenly divide by n?
And then I'm totally lost from here.
Let's put some numbers in: 2 boys can mow 1 acre in 10 days.
Is it: 1 boy can mow 1 acre in 20 days; or 1 boy can mow 1 acre in 0.5 days.
Does one boy do half the work of two boys or, as you suggest, twice the work?
We divide by ##n## because a man does n-times more work than a boy and completes a task in n-times less time.
Let's say 1 man does the work of 4 boys. And 1 boy mows an acre in 20 days. 4 boys mow an acre in 5 days, so 1 man mows an acre in 5 days.
If you multiple by ##n##, then 1 man takes 80 days to mow an acre. Does that make sense?
II will add a few words to what @PeroK has said.
It can help to use made-up values to understand what is going on. Then, after a bit of practice, you can do it without the made-up values.
Make up some values, e.g. c = 5, a = 10, b = 3. This is the same as saying:
5 boys can mow 10 acres in 3 days
First, we want to know how many days for 1 boy to mow 10 acres.
Think carefully at this point. If should be clear that it will take 1 boy longer than 5 boys to do the same job.
How many times longer? 5 times longer. So we need to multiply (not divide) 3 days by 5.
To do the same job (mow 10 acres), 1 boy will take 5 x3 days = 15days. In symbols, the number of days is bc.
Then 1 boy (I assume this means setting c=1) can mow a acres in bc days. If you plug in c=1, then its b days.
But what if I set 10 boys (c=10), then plugging it back in the number of days becomes bc=10b. This is 10 times more days than 1 boy, which makes no sense.
If it was b/c days, then c=1 means it takes b days for 1 boy to mow a acres. For c=2, it takes b/2, or half the time with 2 boys. c=10 it takes b/10 days. 10 boys take only 10% of the time compared to 1 boy. Hence increasing the number of boys proportionally decrease the number of days needed.
Thanks a lot for your help.
No. Working out how long 1 boy takes is not the same as setting c=1. That's not what c means. c can't change. See below.
The important point is: it takes 1 boy bc days (to mow a acres).
You can't set c=10. c can't be changed (see below).
1 boy can coomplete the job in bc days.
10 boys can do the job 10 times quicker than 1 boy, so the time taken by 10 boys is bc/10.
Do not treat c, a and b as variables. They are constants. For example:
c = 5, a = 10, b = 3. c, a and b are fixed initial values,
c, a, and b do not change. You can't (for example) suddenly say c=1. c must stay equal to 5.
If you want the number of boys (N) to complete a job, you express N in terms of c, a, b and any other values supplied.
This is the way I would solve this problem:
It is basically a work or energy related problem, for which power data is given.
Then, I would assemble equations that consider all the given variables in function of time.
Power of c number of boys = a acres / b days
Power of 1 boy = Work / time = a acres / (c boys x b days) (equation 1)
Power of 1 man = Power of n boys = (n x a acres) / (c boys x b days) (equation 2)
Now, here is where the problem has been made purposely confusing:
1) The same variable a has been assigned to number of acres and number of men.
2) The same variable b has been assigned to number of days and number of acres.
Just to work avoiding that confusion, I replace those two last variables in the question with α for the number of men, as well as with β for the number of acres.
In order to please the questioner, I will revert α and β to a and b in the final response.
Therefore; as
time = work / power
From equation 1 above:
Time 1 boy to mow a acres = a acres / [a acres / (c boys x b days)] = c boys x b days
From equation 2 above:
Time 1 man to mow a acres = a acres / [(n x a acres) / (c boys x b days)] = (c boys x b days) / n
Time α men to mow a acres = (Time 1 man to mow a acres) / α = (c boys x b days) / (α men x n)
Time α men to mow 1 acre = (Time α men to mow a acres) / a = (c boys x b days) / (a x α men x n)
Time α men to mow β acres = (Time α men to mow 1 acre) x β acres = (c boys x b days x β acres) / (a x α men x n)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
