Confusing free-body diagrams help
In summary, the conversation involves two problems involving drawing free-body diagrams for a truck accelerating to the right. The first problem involves determining the correct placement of tension and friction forces, while the second problem involves correctly depicting the forces exerted on the truck by the box on its bed.
Kinermatics
1. A truck is pulling a car on a horizontal highway using a horizontal rope. The car is in neutral gear, so we can assume that there is no appreciable friction between its tires and the highway. As the truck is accelerating to highway speeds, draw a free-body diagram of the truck. (Assume that the truck is accelerating to the right.)
2. A large box containing your new computer sits on the bed of your pickup truck. You are stopped at a red light. The light turns green and you stomp on the gas and the truck accelerates. To your horror, the box starts to slide toward the back of the truck. (Assume that the truck is accelerating to the right.) Draw clearly labeled free-body diagram for the truck. (The bed of the truck is not frictionless.)
Just drawing
1. I know i have the weight and the normal force correct (weight pointing down and normal force pointing opposite) however I can't seem to figure out where to put: the Tension force and the Friction force. My first instinct was to put the friction force left (isn't the direction of friction opposite that of motion) and to put the Tension force left (the tension is always pointing towards the rope). Idk somewhere i did something wrong.
2. This part is very confusing. Like the previous problem i know i got the weight and normal force part correct. But for this question they want to know the direction and orientation of: 1. the box's friction force on the truck bed 2. reaction force to tires' backward push 3. reaction to the normal force on the box from the truck.
Here are better illustrations of my attempt:
1.http://img685.imageshack.us/img685/7545/95398466.jpg
Uploaded with ImageShack.us
2.http://img804.imageshack.us/img804/7533/51523982.jpg
labels for 1:
nT = Normal Force
wT = weight of truck
f = friction force
T = tension force
labels for 2:
nground = Normal Force
nB = Reaction to the normal force on the box from the truck
fk = the box's friction force on the truck bed
fread = reaction force to tires' backward push
If both the friction force and tension force acted left, the net force would be left, but the truck is accelerating right. You are correct about the direction of the tension force. Remember that friction force is always opposite to the direction of the relative motion or pending motion beween the surfaces, and that the wheels of the truck are turning clockwise as you view them from the right side (that's a backward push of the tire on the road, as you noted in question 2 below).
Your free body diagram looks good. F_road is the static friction force between the road and the tires.
For #2) You show the box (via its friction force) exerting a forward force on the truck. How does it do that?
for #1 should the frictional force be the same length as the tension force? Cause when i put it in the direction towards the right (and your explanation made a lot of sense, thank you!) it counted it as wrong.
and for #2 the mp counted the diagram wrong, so i guess there is something we missed?
If they were the same length, there would be no net force, but the truck is accelerating right.
Yes, we missed SammyS' comment in Post #4:redface:
Hmm it must be something I'm doing then because here are my attempts so far on #1:
my mind is out of ideas of what the answer could be lol. need some help :"(
and for #2 (taking into consideration SammyS' comment) i put fk (the box's friction force on the truck bed) toward the right because the friction force would have to be in that direction for the box to not move. Or should fk = 0 since when your drawing free body diagram you only include forces acting and that body?
The truck exerts a force on the box which is to the right.
Therefore, the box exerts a force on the truck which is to the   ?   .
You're drawing free body diagrams for the truck, not the box. What forces are exerted on the truck ?
I figured out #2! Thank you good sir!. You where right, I just forgot that the net force for y = 0 which made normal force greater :).
I'll get back to you guys on #1 lol
Related to Confusing free-body diagrams help
1. What is a free-body diagram?
A free-body diagram is a visual representation of the forces acting on an object. It shows all the forces acting on the object and their direction, helping to understand the motion of the object.
2. Why are free-body diagrams important?
Free-body diagrams are important because they help to identify and understand the forces acting on an object. This is crucial in solving physics problems and predicting the motion of objects.
3. How do I create a free-body diagram?
To create a free-body diagram, you first need to identify the object and all the forces acting on it. Then, draw a diagram of the object and represent each force as an arrow, indicating its magnitude and direction.
4. What are some common mistakes when drawing free-body diagrams?
Some common mistakes when drawing free-body diagrams include forgetting to include all the forces, drawing the forces in the wrong direction, and not labeling the forces correctly.
5. How can I use free-body diagrams to solve problems?
To solve problems using free-body diagrams, you can use Newton's Laws of Motion to analyze the forces and determine the resulting motion of the object. You can also use the free-body diagram to find the net force acting on the object and calculate its acceleration.
16K
