Confusing index notation involving grad of w cross r
In summary, the problem asks to evaluate the gradient of a scalar function given by the norm-squared of the cross product of two vectors, both expressed in terms of their cartesian components. To solve this, one must first look up the expression for the gradient of a general scalar function in index notation. Then, the scalar product of a vector with itself and the cross product of two vectors can be expressed in index notation as well. Finally, the gradient can be calculated using these expressions.
troytroy
consider the position vector expressed in terms of its cartesian components, r=xiei. Let w=wjej be a fixed vector whose components wj are constants that do not depend on the xi, so that δwj/δxi = 0
I am trying to evaluate ∇((wXr)^2)
Hi troytroy, welcome to PF!:smile:
What have you tried and where are you stuck?
I am getting confused on where to begin when using index notation for these kind of problems
Well, here you are being asked to calulate the gradient of some scalar function, so a good place to start would be to look up the expression for the gradient of a general scalar function [itex]f[/itex] in index notation. What is that?
Next consider that in this case, the scalar function in question is the scalar product of of a vector with itself, [itex](\mathbf{w}\times\mathbf{r})^2[/itex] (the norm-squared of a vector is usually written as [itex]||\mathbf{v}||^2[/itex], but some authors will use more clumsy notation and just call it [itex]\mathbf{v}^2[/itex]. Either way the norm-squared of a vector is given by the scalar product of a vector with itself). So, how do you express the scalar product of a vector with itself in index notation?
Finally, consider that the vector whose norm-square you are taking the gradient of is, in this case, the cross product of a vector with another vector, [itex]\mathbf{w}\times\mathbf{r}[/itex]. How do you represent a cross product like this in index notation?
The notation ∇((wXr)^2) can be rewritten as ∇(wXr)·∇(wXr), where ∇(wXr) represents the gradient of the vector wXr. Using the chain rule, we can expand this as ∇(wXr)·(∇wXr·∇r + wX∇∇r), where ∇w and ∇r represent the gradients of the vectors w and r, respectively. Since w is a fixed vector with constant components, its gradient is equal to zero, and thus the term ∇wXr becomes zero. This leaves us with ∇(wXr)·wX∇∇r. We can further simplify this by using the identity ∇(wXr) = rX∇w + wX∇r, giving us (rX∇w + wX∇r)·wX∇∇r. This can be expanded as (r·w)(∇w·∇∇r) + (w·w)(∇r·∇∇r). Since w is a fixed vector, its dot product with itself is equal to its magnitude squared, making the second term in the expression equal to ∥w∥^2(∇r·∇∇r). The first term, (r·w)(∇w·∇∇r), can be rewritten as (r·w)(∇w·∇r)·∇r, using the identity ∇∇r = ∇r. Finally, we can substitute back in the original notation to get the expression (r·w)(∇w·∇r)·∇r + ∥w∥^2(∇r·∇r). This may seem like a confusing notation at first, but by breaking it down and using identities, we can simplify it and better understand the meaning behind it.
FAQ: Confusing index notation involving grad of w cross r
What is index notation and how is it used in the context of "grad of w cross r"?
Index notation is a mathematical notation that uses indices or subscripts to represent repeated multiplication or differentiation. In the context of "grad of w cross r", index notation is used to represent the components of the gradient of the cross product of w and r.
How is the gradient of w cross r calculated using index notation?
In index notation, the gradient of w cross r is calculated by taking the partial derivatives of the cross product with respect to each variable and combining them using the cross product rule. This results in a vector with three components, each representing the partial derivative of the cross product with respect to one of the variables.
Can you provide an example of index notation involving the gradient of w cross r?
Sure, let's say we have the function f = w cross r, where w = (w1, w2, w3) and r = (r1, r2, r3). Using index notation, we can represent this as f = fi, where i = 1,2,3. The gradient of f can be written as grad f = (df/dwi), where i = 1,2,3. This means that the gradient of the cross product is a vector with three components, each representing the partial derivative of f with respect to one of the variables.
Why is index notation used in the context of "grad of w cross r" instead of traditional vector notation?
Index notation is often used in more advanced mathematics and physics because it allows for a more compact and concise representation of complex equations. It also makes it easier to perform calculations involving multiple variables and partial derivatives. In the context of "grad of w cross r", index notation helps to clearly represent the components of the gradient vector and simplify the calculation process.
Are there any other notations that can be used to represent "grad of w cross r"?
Yes, there are other notations that can be used to represent the gradient of w cross r, such as matrix notation or component notation. However, index notation is commonly used in this context due to its simplicity and efficiency in representing complex equations involving partial derivatives. Ultimately, the choice of notation depends on the preference of the individual using it and the specific context in which it is being used.
29K
11K
