Confusion about circular motion
In summary: What if somehow we remove only the component of friction?If we only remove the component of friction, the coin will move in a straight line.
sachin123
121
Hello all,I am having a lot of confusion about circular motion.
Consider a hill which is perfectly circular at the top.
When a vehicle passes over it at constant velocity,at the top most point,
I want an expression for Normal reaction force by the hill on the vehicle.
I take a non inertial frame of reference.
mg-N-(mv^2)/r=0 is the equation(symbols have usual meanings).
I understand it(as (mv^2)/r is pseudo force acting upwards).
But,how do we write it wrt to an inertial frame of reference?
Why are you using a non-inertial frame?
Just stick to an inertial frame. What forces act on the vehicle? What is the vehicle's acceleration? Apply Newton's 2nd law.
mg acts downwards and N upwards.They should together maintain a centripetal force:
(mv^2)/r
So,mg-N=(mv^2)/r ?
In this case we could identify the source of force,gravity.
But take this:
a coin on a table rotating about its axis.The coin slips away and falls down.How do you give equation to this?
(mv^2)/r
So,mg-N=(mv^2)/r ?
Yes.
OK.
But take this:
You'll need to describe the problem in more detail. Is the table rotating? Just the coin?
Yes,the table is rotating.A coin is placed over it.It falls off.
We know its radial acceleration is (mv^2)/r.But can you give an equation?
Problems for me is,there should be force to cause motion.Here absence of force is causing it.How do we write an equation then?
What force do you think exists between the table and the coin? If the coin were to remain on the rotating table, what force must be accelerating it?
More on this:
If the coin doesn't slide, it must be radially accelerated. Thus the net force on it will be given by Newton's 2nd law as mv^2/r. What force must act on the coin?
If the table rotates too fast, that force will be insufficient to keep the coin moving in a circle. The coin will start to slide off the table.
The coin is already moving. The lack of sufficient force prevents its motion from being kept in a circle--it just keeps going.
its all abt NEWTON's laws...:approve:
The force is friction.
So the coin need not necessarily accelerate outwards?It only moves with constant velocity right?
And,looking at it from an inertial view,the coin will it will come out tangentially right?
I have this other problem where they ask the centrifugal force on a particle(m) rotating in a circle with radius a with ang speed x1 when seen from a frame rotating at ang speed x2.
Can you help me with this?I am clueless.
Yes. As long as the static friction is sufficient to provide the needed centripetal force, the coin will stay in place with respect to the rotating table.
If the coin moves in a circle, it must accelerate inward--centripetally. Its speed is constant, but its velocity is tangential and continually changing direction as it moves in its path.
If all of a sudden all friction were removed, then the coin would just continue moving tangentially, per Newton's 1st law. In real life, if the speed of rotation is increased, the coin will start to slide as its maximum static friction became inadequate to maintain its position. But it won't move in a straight line, since there would still be dynamic friction acting on it.
Well, what's the formula for calculating centrifugal force?
I was talking about it when it runs off the table.
What if somehow we remove only the component of friction that is responsible for centripetal force(the radial part of friction).Then how would it move?
Dynamic friction would retard the motion.How would it change the path?
FAQ: Confusion about circular motion
What is circular motion?
Circular motion is the movement of an object along a circular path or trajectory. This type of motion is characterized by a constant distance from a central point and a consistent speed.
What causes circular motion?
Circular motion is caused by a centripetal force, which is a force that directs an object towards the center of the circular path. This force can be produced by various factors such as gravity, tension, or friction.
How is circular motion different from linear motion?
The main difference between circular motion and linear motion is the path followed by the object. In circular motion, the object moves along a curved path, while in linear motion, it moves along a straight line. Additionally, circular motion requires a centripetal force, while linear motion does not.
How is circular motion related to velocity and acceleration?
In circular motion, the velocity of the object is constantly changing, as it is always directed tangent to the circular path. This change in velocity results in a non-zero acceleration, which is directed towards the center of the circle. The acceleration in circular motion is known as centripetal acceleration.
What are some real-life examples of circular motion?
There are many examples of circular motion in our daily lives, such as the motion of a Ferris wheel, the orbit of planets around the sun, or the spinning of a top. Other examples include the circular motion of a car on a curved road or the motion of a rollercoaster along its track.
