MHB Confusion about greater variance in the numerator for F ratio
The discussion revolves around the confusion regarding the F ratio and its calculation from two samples drawn from normally distributed populations with equal variance. It clarifies that while the greater variance should ideally be placed in the numerator for consistency, this is more of a convenience rather than a strict requirement. When calculating the F ratio, if the variances are equal, the result will be one, while different variances will yield values greater or less than one. The key point is that each sample has a fixed variance, and the F ratio can be adjusted by placing either variance in the numerator, allowing for flexibility in interpretation. Understanding this concept helps clarify the application of the F distribution in statistical analysis.
dhiraj
Hi,
I am studying about F ratio and how, as a random variable, it follows F Distribution. So let me explain what confuses me.
This is what the theory says -- We draw two random samples $sample_x$ and $sample_y$ from two different Normally distributed populations with equal variance $\sigma^2$. Let the sample variances of these samples be $s^2_x$ and $s^2_y$ respectively. The sample sizes for $sample_x$ is $n_x$ and the sample size for $sample_y$ is $n_y$. Then if we form the random variable $\frac{\sigma^2_x}{\sigma^2_y}$ , such that the greater variance (whichever is the greater variance in that sample pair) must appear appear as the numerator. This is what I am not able to understand.
If it's a random variable for the sampling distribution for that ratio -- it means , if we draw a random sample pair (x,y) with fixed sizes $n_x$ and $n_y$ many many times from their respective parent populations (say we do it 1000 times e.g.), we will get 1000 pairs of variances i.e. ($s^2_x$,$s^2_y$). Now if we have to draw histogram for F distribution , we have to calculate 1000 numbers (ratios) out of each of the 1000 variance pairs ($s^2_x$,$s^2_y$). And the theory says that the greater variance has to appear as numerator in the ratio. Now how can it be fixed? Across all the 1000 pairs it may change, in some of the pairs the sample x (the first) may have higher variance, and in some of them the sample y (the second) can have the greater variance. If we have to have a common fixed formula for the random variable (supposedly $\frac{\sigma^2_x}{\sigma^2_y}$ ), how can it change from pair to pair? It has to remain fixed for all the 1000 instances. This is my dilemma.
Can you try to explain?
Thanks,
Dhiraj
Mathematics news on Phys.org
Hi dhiraj! Welcom to MHB! (Smile)
We don't have to put the largest variance on top - it's a convenience.
Note that if the variances are the same, we have:
$$F=\frac{\sigma_x^2}{\sigma_y^2}=1$$
If the variances are different, we will either have $F>1$ or $F<1$.
It's just that typical $F$-tables only list $F$-values greater than $1$, which makes sense because we can also look up $\frac 1 F$, which is what we have if we put the other variance on top.
So yes, we should always put the same variance on top, because we should indeed be consistent.
And initially (or afterwards) we might make an 'educated guess', which variance we think will be bigger, and put it on top, just so we get 'nice' numbers (that are mostly greater than $1$).
"Across all the 1000 pairs it may change, in some of the pairs the sample x (the first) may have higher variance, and in some of them the sample y (the second) can have the greater variance."
You seem to be under the impression that the "x" and "y" of each sample has its own "variance". That is not true. The probability distribution for x has a single variance and the probability distribution for y has a single variance.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
