Confusion about index notation and operations of GR
In summary: Gravitation". <<amazon link>>.Some of the other notation in MTW might be confusing though, the semicolon notation in particular. There may be other books or sources that use the "stacks of plates" idea.A toy example might help. Suppose you have a 3-d hill, and a 2d contour map of the hill. The "stacks of plates" idea is like the spacing of the lines of the contour map. Vectors, as little arrows, are displacements. The idea of vectors as displacmenets are dangerous in general, be warned, so this may not be the ideal example. Still, it
Put1demerde
Hello,
I am an undergrad currently trying to understand General Relativity. I am reading Sean Carroll's Spacetime and Geometry and I understand the physics (to a certain degree) but I am having trouble understanding the notation used as well as the ideas for tensors, dual vectors and the mathematics behind them. It is mainly that I cannot visualize the mathematical operations used on tensors as such. Are there any good references that I could look into that simply explain the notation? I think once I get this, the pace should increase but for now I'm stuck.
Thanks!
Put1demerde said:
Hello,
Thanks!
If you don’t have a very firm grasp on linear algebra and vector calculus, I’d recommend starting with “Vector Calculus, Linear Algebra, and Differential Forms: A Unified Approach” by the Hubbards. After that, “Tensor Calculus” (Schaum’s Outline) by David Kay is great if you’re like me and you need a lot of examples to work through to really get a good grasp on the concepts. After that, you should be ready to grasp most of the concepts in many GR books.
Likes Put1demerde
Put1demerde said:
Hello,
Thanks!
I'm not sure if this helps, but you can visualize vectors as little arrows, and their duals as "stacks of plates". The former idea, vectors as little arrows, is probably pretty familar. The latter is a bit unusual, but the point is that the number of plates in the stack that the little arrow pierces is a scalar, this mimics the way that dual vectors are maps of (vectors to scalars). The stack-of-plates creates a map from the little arrows (vectors) to a number (the number of plates the arrow pierces).
This particular visual aid is described in MTW's big black book, "Gravitation". <<amazon link>>.
A toy example might help. Suppose you have a 3-d hill, and a 2d contour map of the hill. The "stacks of plates" idea is like the spacing of the lines of the contour map. Vectors, as little arrows, are displacements. The idea of vectors as displacmenets are dangerous in general, be warned, so this may not be the ideal example. Still, it might give you the push you need to appreciate the graphical symbolism of vectors as arrows and their duals as stacks-of-plates. The mathematical point here is that the gradient of the hill, ##\nabla_a##, is an example of a dual vector, because it's subscripted, making it different from the vectors, that are superscripted.
WIth an understanding of vectors and dual vectors as geometric objects, the arrows and plate stacks, one next needs to know that the metric tensor can convert vectors into their duals, and the inverse metric can convert dual vectors into vectors. Put another way, it can raise and lower indices.
I'm going to stop here for now, and see how you react. Anyway, MTW has it's own notational issues, but it can offer some nice insights, too.
Likes Pencilvester and Put1demerde
Thank you so much! This makes a lot more sense. I picked up a copy of "Gravitation" a couple days ago to use but I haven't looked through it enough.
So far, everything you've said makes sense except the gradient ##\nabla_a## being subscripted. I don't understand the whole convention that something is subscripted/superscripted and therefore makes it a certain mathematical object (vector or dual vector)– wouldn't it be that because it is a dual vector it is subscripted (I don't mean to be nitpicky. This is definitely something I am having trouble understanding–the whole superscript/subscript thing– and want to solidify my intuition ). So how do the subscripts/superscripts apply to tensors?
Also, raising and lowering indices: If I want to raise the indices to a tensor (for example ##X_{\mu\nu}##) I would use the minkowski metric tensor ##\eta^{\rho\sigma}## (although it seems this is only for flat spacetime and the metric tensor ##g_{\mu\nu}## will replace it for curved spacetime), for instance, to raise one of the indices, we would perform:
##\eta^{\rho\nu}####X_{\mu\nu}## = ##X_{\mu}{}^{\rho}## ##\rightarrow## I hope this is right... (my intuition says that the same components will cancel and because they are on the right of the other superscript, and thus the new index will be on the right)
But then what if I want to find the components of ##X_{\mu}{}^{\nu}##? I can't just switch the indices I don't want, or is this the purpose of dummy indices? I doubt I can have a metric tensor with the same indices.
Moreover, what's the difference in performing ##\eta^{\rho\nu}####X_{\mu\nu}## = ##X_{\mu}{}^{\rho}## and ##\eta_{\rho\nu}####X_{\mu\nu}## = ##X_{\mu}{}^{\rho}## if ##\eta^{\rho\nu}## = ##\eta_{\rho\nu}##. I know this may seem like absolute blasphemy and I know it's not correct, but why?
Also, how would the math work out for this. If I know the components of ##X_{\mu\nu}##, how could I work out the new components of ##X_{\mu}{}^{\nu}##?
I'm sorry for so many questions
Thank you for the suggestion! I learn best from examples and working out problems so I will definitely look into this.
Just a couple of points:
1) Don't expect this to be easy. I think getting to grips with this is quite challenging. Be prepared to get knocked back a few times.
2) The gradient doesn't magically become a dual vector just because of the position of the script! There's a bit of mathematics needed to prove that the gradient behaves like a dual vector.
3) The concept of vectors as "directional derivatives" is key and, again, not that easy to grasp. Be prepared to work on this for a while.
4) Fundamentally, the superscripting and subscripting is designed to keep track of what basis or bases you are using. In a lot of standard linear algebra the basis and dual basis coincide, hence there is no need to use upper and lower indices. In GR you do not have that simplicity, hence the need for the upper and lower indexing.
Likes Put1demerde
It's a bit tricky to explain properly. I'm going to focus on the components, because I find that easiest. Let u be a vector, and v be it's dual. Then ##u^a## gives the components of a vector, where a is an index which usually takes the range {0,1,2,3}. These components actually multiply the basis vectors themselves. It gets a bit tricky when one is talking about the vector u, the components (which are superscripted) multiply the actual vectors in some chosen basis.
If we think of vectors as little arrows, we have some set of little arrows, that form a basis when we work with vectors. So the first step is to create this basis. Then the weighted sum of these basis vectors, weighted by the components ##u^a##, form an expression for an arbitrary vector in that basis.
For the dual vector, it's components are given by ##v_a##, where again a is in the range {0,1,2,3}.
So far this is right, though ##g_{ab}## would lower indices, and the inverse metric ##g^{ab}## would raise indices. In flat space time ##\eta_{ab}## lowers indices and ##\eta^{ab}## raises them.
I don't quite understand this. Does my remark about raising indices with the inverse metric and lowering them with the metric help any?
I can tell you it's wrong, but I can't tell you why you think it might be right. I can tell you that if we take a more complex but still flat space-time case metric like
$$g_{ab} = \begin{bmatrix}
2 & 0 \\ 0 & 1
\end{bmatrix}$$
it's inverse is
$$g^{ab} =
\begin{bmatrix}
\frac{1}{2} & 0 \\ 0 & 1
\end{bmatrix}$$
So you have to pay attention to the rules to get results that aren't nonsense if you have a flat space metric other than ##\eta_{ab}##.
Another useful case to consider is polar coordinates, r, ##\phi## where the metric is
$$g_{ab} = \begin{bmatrix} 1 & 0 \\ 0 & r^2 \end{bmatrix}$$
and the inverse matrix is
$$g^{ab} = \begin{bmatrix} 1 & 0 \\ 0 &\frac{1}{ r^2} \end{bmatrix}$$
Likes dextercioby and PeroK
Related to Confusion about index notation and operations of GR
1. What is index notation in general relativity (GR)?
Index notation is a mathematical notation used in general relativity to represent tensors, which are objects that describe the curvature of spacetime. It uses indices, or subscripts, to represent the different components of a tensor and allows for compact and efficient representation of complex equations.
2. What are the common operations used in index notation in GR?
The most commonly used operations in index notation in GR are contraction, raising and lowering indices, and covariant differentiation. Contraction involves summing over repeated indices to simplify expressions, while raising and lowering indices allows for the transformation between different types of tensors. Covariant differentiation is used to calculate the curvature of spacetime.
3. How do I know which indices to contract in a given equation?
In general, when contracting indices, you should look for repeated indices that appear in both the upper and lower positions. These indices can be summed over, and the resulting expression will be invariant under coordinate transformations. However, it is important to keep in mind the rules for index placement and the properties of the tensors involved in order to correctly contract indices.
4. What is the significance of index placement in GR?
Index placement in GR is crucial as it determines the type and properties of the tensor being represented. Upper indices represent contravariant tensors, which transform in the opposite way to coordinate transformations, while lower indices represent covariant tensors, which transform in the same way as coordinate transformations. The placement of indices also determines which operations can be performed on the tensor.
5. How can I improve my understanding of index notation and operations in GR?
The best way to improve your understanding of index notation and operations in GR is through practice and familiarizing yourself with the rules and properties of tensors. It can also be helpful to work through examples and seek out additional resources, such as textbooks or online tutorials, to gain a deeper understanding of the subject.
