Confusion about physics vectors in question
In summary, the engineers performed a crash test with a minivan and a compact car. The mass of the minivan is 800kg and the mass of the compact car is 560kg. The minivan was moving north, and the compact was was moving east. After the collision, the two cars crumpled together and moved at 15m/s [N 30 E]. Determine the initial velocity of each vehicle. x: m1v1 + m2v2 = mtvf m2v2 = mtvf 560 * v2 = (560+800)(15*cos70) v2 = 12.45 m/s [E] y: m1v1 + m2v2 = m
Engineers perform a crash test with a minivan and a compact car. The mass of the minivan is 800kg and the mass of the compact car is 560kg. The minivan was moving north, and the compact was was moving east.
P = mv
Okay so its inelastic:
Minivan is 1
Compact car is 2
x:
m1v1 + m2v2 = mtvf
m2v2 = mtvf
v2 = 12.45 m/s [E]
y:
m1v1 + m2v2 = mtvf
800*v2 = (560+800)(15*sin70)
v2 = 24 m/s [N]
The confusion is that these answers are wrong. The book gets completely different answers, and I've discovered its because the book does it like this
How the book is doing it
x:
m1v1 + m2v2 = mtvf
m2v2 = mtvf
560 * v2 = (560+800)(15*sin30)
v2 = 18 m/s [E]
y:
m1v1 + m2v2 = mtvf
800*v2 = (560+800)(15*cos30)
v2 = 22 m/s [N]
This is so confusing for me. Why is the book using sin30 where I use cos70, and why is the book using cos30 where I am using sin70?
I drew the triangle, and I just can't understand why the book is doing it like this. Can someone clear this up? Thanks
I realize this is a trigonometry question. But why isn't sin70 equal to cos30 in the triangle I am drawing? Whats going on?
sin 70 is equivalent to cos 20 not cos 30
sin 60 is equivalent to cos 30
angles must add to 90 not 100
Thank you, solves all my problems. I fail at math today. I was thinking 70 + 30 = 90.
Perhaps you should first explain where your 70 degree measure came from, if the only angle mentioned in the problem is 30 degree.
Everything is solved now, but what I did was I transformed the triangle and set 70 degrees as theta. It should have been 60 degrees, but I wasn't using a calculator so I assumed 90-30 was 70 for some reason
FAQ: Confusion about physics vectors in question
What are physics vectors?
Physics vectors are mathematical quantities that have both magnitude and direction. They are used to represent physical quantities such as displacement, velocity, and force.
How are vectors represented in physics?
Vectors are typically represented graphically as arrows. The length of the arrow represents the magnitude of the vector, and the direction of the arrow represents the direction of the vector.
What is the difference between a scalar and a vector?
A scalar is a quantity that has only magnitude, while a vector has both magnitude and direction. Examples of scalars include temperature and time, while examples of vectors include velocity and acceleration.
Why is it important to understand vectors in physics?
Vectors are essential in physics because they allow us to accurately describe and analyze the motion and forces of objects in the physical world. They help us understand the relationship between different physical quantities and make predictions about the behavior of objects.
What are some common sources of confusion about physics vectors?
Some common sources of confusion about physics vectors include understanding vector addition and subtraction, differentiating between displacement and distance, and using the correct notation for vectors (e.g. using bold letters or arrows to represent vectors).
