Confusion about ##\sqrt{x^2}= \left| x \right|##
  • Thread starter Thread starter RChristenk
    algebra-precalculus
The equation ##\sqrt{x^2} = |x|## is defined to ensure that the square root function always yields a non-negative result. For positive values of ##x##, such as ##4##, the equation holds true as expected. However, for negative values like ##-4##, the square root of the square still results in a positive value, specifically ##4##. This demonstrates that ##\sqrt{x^2} \ne x## when ##x## is negative, highlighting the necessity of the absolute value to accurately represent the output. The absolute value is crucial to prevent confusion and ensure the equation is valid for all real numbers.
RChristenk
Absolute value concept
By definition, ##\sqrt{x^2}= \left| x \right|##.
For positive ##x##, such as ##4##, it is quite straightforward: ##\sqrt{4^2}=\sqrt{16}=4##.
For negative values, I am more confused: ##\sqrt{(-4)^2}=\sqrt{16}=4##. The answer will always be positive, even if you put in a negative value. So why is there a need for the absolute value on the right side? Wouldn't ##\sqrt{x^2}=x## always work? Because after ##x^2## inside the square root, the value will always be positive.
I am guessing the absolute value is to prevent something like ##\sqrt{(-4)^2} = -4##, but if you just focus on the operation on the left hand side of the equal sign, it is not possible to ever end up with a negative value on the right hand side. So why the need for the absolute value? Thanks.
Because ##\sqrt{(-4)^2}=4 \ne -4##. So this is an example of why ##\sqrt{x^2} \ne x##.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
