Confusion about the nature of torque.
In summary, the conversation discusses the concept of torque and its definition as the product of perpendicular distance and force. The idea is illustrated through an example of a rotating bar and how the distance and force affect the work done. It is also mentioned that this explanation is not related to Newton's laws, but rather to the conservation of energy.
siddharth5129
94
I just read another post on this website about torque and the reason for its definition as the product of the perpendicular distance of the point of application of the force from the axis of rotation and the force itself ( ignoring the vector properties of the above quantities). The explanation by one of the users gives an intuitive experimental verification process about tightening a screw using your fingers and using a wrench to do the same( which requires far less force) and states that it is a fundamental observation and is just the way things work. I don't know if this is entirely true. Can a justification for the above be drawn in terms of Newton's laws ( which i think are the set of fundamental observations in this case and are "just the way things work." ).
Excellent question. Its admirable to seek out a true understanding of these simple concepts that so many people gloss over.
The way I try to think about torque, is in terms of conservations. You can think about the following example in terms of wrenches or in terms of levers, its the same idea. Consider a solid, rigid metal bar, fixed to rotate about its left end. Slightly to the right (lets say, point 'A') is some object that its doing work on as it is rotated (e.g. compressing a spring, or tightening a screw). At the opposite end (the right-end, let's call it point 'B'), you are able to turn the bar (exert a force on it).
As you push upon point B, and rotate the bar by some small amount, point A will be moved a lesser distance (or angle, or whatever). Thus for the work ([tex]W = F \times d[/tex]) to be the same, the force is greater at A than at B, because the distance traversed is lesser at A than at B.
This is also the reason why only the perpendicular distance is relevant to the calculation, as it effects the change in traversed-distance for the two points. This is the same as for a 'parallax,' there must be a separation perpendicular to the direction of relative motion.
hey thanks zhermes... that makes sense. But could this be explained in terms of Newtons laws. I was thinking something along the lines of rate of change of velocity of a point(which would be more for a point closer to the axis and less for a point further away , given the same displacement of the point) . But i seem unable to draw up a satisfactory explanation from there.
No, Newton's laws of motion have no application here- how fast you turn the screw has nothing to do with the force. It is entirely "conservation of energy" and "work= force times distance" as zhermes says.
I understand the confusion surrounding the concept of torque and its definition. While the explanation provided by the user about tightening a screw using fingers and a wrench is a useful visualization, it is not entirely accurate.
Torque is defined as the product of the distance from the axis of rotation and the force applied perpendicular to that distance. This definition is based on the fundamental principles of rotational motion and can be derived from Newton's laws of motion.
According to Newton's first law, an object at rest will remain at rest unless acted upon by an external force. In the case of a screw, the force applied by the fingers or the wrench causes a rotational motion around the axis of rotation. This force must be applied at a certain distance from the axis in order to produce a torque that will overcome the resistance of the screw and cause it to rotate.
Newton's second law states that the acceleration of an object is directly proportional to the net force applied and inversely proportional to its mass. In the case of a screw, the force applied by the fingers or the wrench is the net force acting on the screw, and the mass is the resistance of the screw. The greater the distance from the axis of rotation, the larger the torque produced and the greater the acceleration of the screw.
Finally, Newton's third law states that for every action, there is an equal and opposite reaction. In the case of a screw being tightened, the force applied by the fingers or the wrench is countered by an equal and opposite force from the resistance of the screw. This reaction force creates a torque that causes the screw to rotate.
In summary, the definition of torque can be justified in terms of Newton's laws of motion. It is a fundamental concept in rotational motion and is essential for understanding the mechanics of everyday objects. While the explanation provided by the user may be a useful visualization, it is important to understand the scientific principles behind the concept of torque.
FAQ: Confusion about the nature of torque.
What is torque?
Torque is a measure of the force that causes an object to rotate about an axis. It is commonly represented by the symbol "τ" or "T" and is given in units of Newton-meters (N·m).
How is torque different from force?
Force and torque are related but distinct concepts. Force is a push or pull on an object, while torque is the twisting or turning force that is applied to an object to make it rotate. In other words, force causes linear motion, while torque causes rotational motion.
What factors affect torque?
The magnitude of torque depends on two main factors: the amount of force applied and the distance from the axis of rotation. The longer the distance from the axis of rotation, the greater the torque will be for a given amount of force.
How is torque calculated?
To calculate torque, you need to know the amount of force applied and the distance from the axis of rotation. The formula for torque is τ = r x F, where τ is torque, r is the distance from the axis of rotation, and F is the force applied.
What are some real-world applications of torque?
Torque is a fundamental concept in many fields, including physics, engineering, and mechanics. It is used in various applications, such as engines, motors, and levers, to produce rotational motion and control the movement of objects.
78K
