Confusion in explaining Kepler's second law in terms of energy
In summary, Kepler's 2nd law of planetary motion can be explained through conservation of energy or conservation of angular momentum.
thebosonbreaker
32
Hello.
As I understand it, Kepler's 2nd law of planetary motion can be explained through conservation of energy or conservation of angular momentum.
I am having trouble with the conservation of energy explanation.
We know that the sum of potential and kinetic energy of a planet in orbit around the parent star (let's assume it's the sun) must be constant (for all points in the orbit) so that energy is conserved. This is fine.
By Kepler's 1st law, the orbit is elliptical. When the planet is closer to the sun, it is moving faster, so it must have more KE. But if it has more KE, it must have less PE, so that PE + KE stays constant.
What I don't understand is why the potential energy is less when the planet is closer to the sun. The potential energy of a body in the gravitational field of another body is given by the equation GMm / r, in which r is the distance between the bodies.
When the planet is closer to the sun, r is smaller. Does this not imply a larger potential energy (not a smaller one) and hence a smaller kinetic energy (not a larger one)? I am confused here!
Any help/clarification would be much appreciated.
Many thanks.
Science news on Phys.org
It's ##-\frac{GMm}{r}##
The minus is important.
Likes Dale
Kepler's second law is a consequence of conservation of angular momentum. Conservation of energy cannot "explain" it.
Potential energy means there is a potential or reservoir for kinetic energy "later" and by applying work you can increasing that potential energy, i.e "store" more energy into that reservoir. If you are out walking on a hill, you have to work for it to go upwards (you are increasing your gravitational potential energy) and visa versa going down-hill. This surely means potential energy must increase with height, right?
Also when dealing with potential energy it is also worth to remember that its all about work going in and out so potential energy in a particular system is determined except for a constant (of integration). If you describe the potential energy of a particular system as ##V(x)## then an equally valid potential is ##V_C(x) = V(x) + C##, where ##C## is a constant. As PeroK mentioned, for gravity one usually write the potential with a minus and no constant, which effectively implies the convention that gravitational potential energy of a mass is zero when you are infinitely far away from it. If you are still confused try plot the gravitational potential function as a function of ##r## and notice if potential energy is increasing or decreasing when you increase ##r## (i.e. when you go up-hill).
FAQ: Confusion in explaining Kepler's second law in terms of energy
What is Kepler's second law?
Kepler's second law, also known as the law of equal areas, states that an imaginary line connecting a planet to the sun will sweep out equal areas in equal amounts of time. This means that a planet will move faster when it is closer to the sun and slower when it is farther away.
How is energy related to Kepler's second law?
Energy plays a crucial role in understanding Kepler's second law. According to the law of conservation of energy, the total energy of a system remains constant. In the case of a planet orbiting the sun, this means that as the planet moves closer to the sun, its potential energy decreases while its kinetic energy increases, and vice versa.
Why is it confusing to explain Kepler's second law in terms of energy?
Many people find it confusing to understand Kepler's second law in terms of energy because it involves both the concepts of potential and kinetic energy, as well as the relationship between them. Additionally, the idea of equal areas being swept out in equal amounts of time can be difficult to visualize and understand.
How does Kepler's second law help us understand planetary motion?
Kepler's second law is one of the three laws of planetary motion that were developed by Johannes Kepler in the 17th century. It helps us understand how planets move in their orbits around the sun and why they do so at varying speeds. This law also allows us to make predictions about the motion of planets and other objects in our solar system.
What are some real-world applications of Kepler's second law?
Kepler's second law has many real-world applications, including in space exploration and satellite orbits. By understanding the relationship between a planet's distance from the sun and its speed, scientists can plan and execute missions to other planets more efficiently. This law also helps engineers design satellite orbits that are stable and efficient for communication and other purposes.
