Confusion in notation of Lorentz Transformations
In summary, the Lorentz transformations between a Frame and bar-O are given by:$$\Delta x^{\bar{0}} = \gamma\left(\Delta x^0 - v\Delta x^1\right)$$$$\Delta x^{\bar{1}} = \gamma\left(\Delta x^1 - v\Delta x^0 \right)$$$$\Delta x^{\bar{2}} = \Delta x^{2}$$$$\Delta x^{\bar{3}} = \Delta x^{3}$$where ##\gamma = 1/\sqrt{1- v^2}## and ##\
Hamiltonian
296
193
##\bar{\mathcal{O}}## is moving with a velocity ##v## relative to ##\mathcal{O}## along ##x^{1}##
The Lorentz transformations between a Frame ##\mathcal{O}## and ##\bar{\mathcal{O}}## is given by:
and ##\mu \in [0, 1, 2, 3]##
In MIT 8.962, the prof. writes the Lorentz transformations as:
$$\Delta x^{\bar{\mu}} = \sum_{\nu = 0}^{3} \wedge_{\nu}^{\bar{\mu}} \Delta x^{\mu}$$
what does ##\wedge_{\nu}^{\bar{\mu}}## represent and how is the above equation equivalent to the Lorentz transformations?
##\Lambda_{\nu}^{\bar{\mu}}## represents the 16 components of the matrix$$
\Lambda = \begin{pmatrix}
\gamma & -\gamma v & 0 & 0 \\
-\gamma v & \gamma & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 &0 & 0 & 1
\end{pmatrix}
Likes Ibix and Hamiltonian
It's a capital \Lambda, not a wedge. He's just converted a system of linear equations into a matrix form (which Dr Greg beat me to writing out). If you write the coordinate differences as column vectors, you'll find that ##\vec{\Delta x'}=\Lambda\vec {\Delta x}##, and that the prof's notation is equivalent to that matrix multiplication, which is equivalent to your four equations.
Likes Hamiltonian
The prof. in his second lecture says that its very obvious to think of ##\Lambda^{\bar{\mu}}_{\nu}## as a matrix and the coordinate differences as column vectors, but we should going forward(in our studies of GR) not think of them as that. I didn't understand why he said this?
I would have said that the Lorentz transform is a special case of the Jacobian matrix, to be honest. But it's true that vectors (and tensors, more generally) in differential geometry don't obey the same rules of grammar as matrices do. For example, it's tempting to say that a two index tensor like the metric, ##g_{ab}##, is a 4×4 tensor. But it's perfectly legal to write ##g_{ab}v^au^b## (where sums over ##a## and ##b## are implied) and if you try to write that as a matrix equation it's illegal.
You can work around it with a sufficiently flexible definition of "matrix", but it's certainly not as simple as you might guess.
Likes Hamiltonian
A Lorentz Transformation, technically, has a physical description relating to a transformation from one IRF to another.
The Lorentz Transformations form a mathematical group, called the Lorentz Group. This means essentially that the composition of two Lorentz Transformations is another Lorentz transformation. I.e. if ##L_1## and ##L_2## are Lorentz Transformations, then so is ##L_2 \circ L_1##. Note that this is saying something important physically about the nature of inertial frames and inertial motion. Think about it!
If we stick with Cartesian coordinates and a certain convention for alignment of axes between frames, then each Lorentz Transformation may be written as a 4x4 matrix. This is more generally called a representation of the group. I think it's too early in your studies to be worried about this. That said, group representations appear all over physics so you will eventually have to grasp the concept. That's probably why your Professor cautioned about getting too attached to one particular representation of the Lorentz Group.
In this case, we have a representation of the Lorentz Group as a set of 4x4 matrices with the following property:
##\Lambda## is a Lorentz Transformation if
$$\eta_{ab}\Lambda^a_c \Lambda^b_d = \eta_{cd}$$Where ##\eta## is the diagonal matrix
\eta = \begin{pmatrix}
-1 & 0 & 0 & 0 \\
0 & 1 & 0 & 0 \\
0 & 0 & 1 & 0 \\
0 &0 & 0 & 1
\end{pmatrix}
$$This means that a Lorentz Transformation leaves the metric unchanged. Note that an alternative, equivalent definition is that$$\Lambda^T\eta \Lambda = \eta$$An exercise, if you want, is to show that the example of a Lorentz Transformation (boost of ##v## in the x-direction) given by @DrGreg above satisfies this definition.
PS and, if you want a bit of practice at abstract algebra, you could show that this does indeed define a group of matrices.
Likes cianfa72 and Hamiltonian
Just to avoid confusion maybe it would be better to use two different symbols for the same Lorentz transformation: ##{\Lambda^{a}}_b## for index notation and ##\hat \Lambda## for matrix notation.
Likes dextercioby
FAQ: Confusion in notation of Lorentz Transformations
What is the Lorentz Transformation?
The Lorentz Transformation is a mathematical equation used in special relativity to describe how measurements of space and time change between two reference frames that are moving at constant velocities relative to each other.
Why is there confusion in the notation of Lorentz Transformations?
There is confusion in the notation of Lorentz Transformations because there are multiple ways to represent the equations, and different fields of science and mathematics may use different notations. This can lead to misunderstandings and mistakes when communicating about the equations.
What are the different notations used for Lorentz Transformations?
Some common notations for Lorentz Transformations include the standard notation using Greek letters (such as γ for the Lorentz factor), the matrix notation, and the hyperbolic trigonometric notation. Other notations may also be used in specific contexts or by individual researchers.
How can I avoid confusion when using Lorentz Transformations?
To avoid confusion, it is important to clearly define and communicate which notation is being used when discussing Lorentz Transformations. It can also be helpful to familiarize yourself with the different notations and their relationships to each other.
Are there any resources available to help with understanding the notation of Lorentz Transformations?
Yes, there are many resources available online and in textbooks that explain the different notations and how they relate to each other. It can also be helpful to consult with experts in the field for clarification and guidance.
