- #36
- 4,126
- 1,722
I had in mind the definition used by John Lee in his 'Riemannian Manifolds'. That is that a connection is a function ##\nabla:TM\times\mathscr{T}(M)\to TM## for which ##\nabla(X,V)\equiv \nabla_XV## is in the same tangent space as ##X##, and that satisfies the three linearity conditions:lavinia said:What definition of connection are you using?
(1) ##\nabla_{fX_1+gX_2}Y=f\nabla_{X_1}Y+g\nabla_{X_2}Y## for ##f,g\in C^\infty(M)##.
(2) ##\nabla_X(aY_1+bY_2)=a\nabla_XY_1+b\nabla_XY_2## for ##a,b\in\mathbb{R}##
(3) ##\nabla_X(fY)=f\nabla_XY+(Xf)Y## for ##f\in C^\infty(M)##
In (3) ##Xf## denotes is the derivative of scalar function ##f## in direction ##X## which I think is OK to use because - as ##f## is a scalar function - it can be defined without using the connection.
Given a curve ##\gamma## that passes through ##p\in M##, the parallel transport ##U_{(V,\gamma)}## of a vector ##V\in T_pM## along ##\gamma## is a (I think, unique) vector field on the image of ##\gamma## that satisfies:Which definition of parallel transport are you using?
(a) ##\nabla_{\dot{\gamma}(s)}(U_{(V,\gamma)}(\gamma(s))=0## for all ##s## in the domain of ##\gamma##
(b) ##U_{(V,\gamma)}(p)=V##
There's one thing that bothers me here, which is that the second argument to the map ##\nabla## in (a) is a vector field on image ##\gamma##, whereas ##\nabla## requires it to be a vector field on an open subset of ##M##. I have a construction in mind that I think could probably make that robust in a small neighbourhood of ##p##, but I haven't had time to think it through fully yet, let alone to code it up here.
