Confusion regarding 2 dimension motion
In summary, projectile motion consists of horizontal and vertical motion, with the horizontal motion having a constant velocity and the vertical motion having a constant acceleration due to gravity. The initial angle θ and initial velocity v determine the initial vertical and horizontal velocities, and these values change over time as the projectile moves. The equations vsinΘ+0.5gt^2 and vcosΘ represent the vertical and horizontal component of velocity, respectively, and can be used to calculate the speed and direction of the projectile at any given time.
negation
818
Projectile motion consist of horizontal and vertical motion.
The horizontal motion consists only of constant velocity, that is, the velocity of the object
The vertical motion consists only of constant acceleration, that is, acceleration due to gravity.
Yet...
we have vx = vcos
and
vy = vsinΘ
can someone the concept?
Yes, your statement "The vertical motion consists only of constant acceleration" is not accurate.
If a projectile is fired at an angle to the horizon, the initial vertical velocity Vy = V * sin (theta)
During flight, the Vy component of projectile velocity decreases under the action of gravity until Vy = 0, at which point the projectile begins to fall back to earth.
So vertical motion has vertical velocity expressed mathematically as vsinΘ+0.5gt^2
whereas
horizontal motion has velocity expressed as vcosΘ with no acceleration due to gravity?
The angle θ relates to the initial velocity. After that the projectile will be moving at a different angle.
So, in these problems, θ is the initial angle that determines the initial vertical and horizontal velocity.
If you want to, you could look at the angle θ(t) as this changes with time as the projectile moves. This would depend on the initial θ = θ(0), the initial angle of the projectile.
The important point is that θ is the initial angle.
Regardless of the change of θ, the equation vsinΘ+0.5gt^2 is correct expression for vertical component of motion. Here θ is initial angle.
Gravity acts toward the center of mass of the attracting body. This is why the vertical velocity is affected by gravity, but not the horizontal velocity.
It's important to distinguish the initial speed and direction (angle) at t = 0 from the speed and direction at a later time t. We often do this by writing the initial values as v0 and θ0.
At time t the velocity components are
$$v_x = v_0 \cos \theta_0 \\
v_y = v_0 \sin \theta_0 - \frac{1}{2}gt^2$$
whereas the speed and direction are
$$v = \sqrt{v_x^2 + v_y^2} = \sqrt{(v_0 \cos \theta_0)^2 + \left(v_0 \sin \theta_0 - \frac{1}{2}gt^2\right)^2}\\
\theta = \tan^{-1}\left(\frac{v_y}{v_x}\right) = \tan^{-1}\left( \frac {v_0 \sin \theta_0 - \frac{1}{2}gt^2} {v_0 \cos \theta_0}\right)$$
Related to Confusion regarding 2 dimension motion
What is 2 dimension motion?
2 dimension motion refers to the movement of an object in two perpendicular directions, typically represented as the x and y axes. This type of motion is commonly seen in projectile motion, where an object moves in both the horizontal and vertical directions simultaneously.
What is the difference between 2 dimension motion and 1 dimension motion?
The main difference between 2 dimension motion and 1 dimension motion is the number of directions the object is moving in. 1 dimension motion only involves movement along a single axis, while 2 dimension motion involves movement in two perpendicular axes simultaneously.
How is 2 dimension motion represented mathematically?
In 2 dimension motion, the position of an object is represented by two coordinates, typically x and y. The displacement of the object is calculated using the Pythagorean theorem, taking into account both the horizontal and vertical components of the motion.
What are some real-life examples of 2 dimension motion?
Some examples of 2 dimension motion include a ball being thrown at an angle, a bird flying in the sky, and a car driving on a curved road. Essentially, any object that moves in two perpendicular directions at the same time can be considered as exhibiting 2 dimension motion.
What are some common misconceptions about 2 dimension motion?
One common misconception is that objects in 2 dimension motion always follow a curved path. In reality, the path of the object can be either curved or straight depending on the initial velocity and angle of launch. Another misconception is that the horizontal and vertical components of motion are independent of each other, when in fact they are interrelated and affect the overall motion of the object.
17K
