Confusion regarding application of Conservation of Momentum
In summary, the two questions had different problems that the author attempted to solve using the same equation, but got different results. He is confused about whether to add the external particle moment of inertia in "ICMω2". If he does, he gets another answer that is not correct. He needs to consult a book answer to find out the correct relationship between v1 and ω.
Amartya Sen
Actually, my confusion originated from solving two different problems...
1) A point object of mass 'm' moving horizontally hits the lower end of the uniform thin rod of length 'l' and mass 'm' and sticks to it. The rod is resting on a horizontal, frictionless surface and pivoted at the other end as shown in figure. Find out just after collision the angular velocity of the system.
2) A circular wooden loop of mass 'm' and radius 'R' rests flat on a horizontal frictionless surface. A bullet, also of mass 'm', and moving with a velocity 'V', strikes the loop tangentially and gets embedded in it. The thickness of the loop is much less than 'R'. The angular velocity with which the system rotates after the bullet strikes the loop is ...
[/B]
mrCMvCM +ICM ω2 = constant
[/B]
I solved both questions using the above formula exactly in the same way, but was able to solve only (1)...
What I am confused with is that whether to add the external particle moment of inertia in "ICMω2"
I applied the formula independently for both objects, that means the particle's MoI about its own CM is 0.
I get the answer in (2) if I add Consider the MoI of the ring to be 2mR2 instead of simply mR2...
If I follow this approach in (1), then I get another answer which is not correct...
What to do??
Any help would be greatly appreciated.
Hello Amartya,
I hesitate to comment (see reason below), but I do notice two things:
That is correct and a good assumption: the size of the bullet isn't given and it can be thought of as a point mass. However, the axis of the rotational movement is executes after the collision is probably not through the COM of the bullet !
That may well be, but the ring has a moment of inertia for rotations about its axis through the center of mass (perpendicular to the plane) that really is no more than mR2.
Now my hesitation: After the collision you have an expression for the momentum of the center of mass. It's not in your list of relevant equations, but I do think you need it. The motion is split in two: the linear motion of the center of mass plus a rotation around it. So the axis of rotation is supposed to be the center of mass and you will need the moment of inertia of ring+bullet around this axis.
From the book answer it would almost seem the rotation could be around the center of the ring, which I think is not correct. @Doc Al ?
I get v/(3r), which I assume is correct, without such a cheat.
I took moments about the point of impact, as a point fixed in space.
Please post your working.
Thanks haru ! Smart approach!
Yes.! That's right! The correct answer is V/3R
Pardon, but I didn't understand your solution. You conserved angular momentum about point of contact ?
OK..., let me clear my basics first of all..,
  • I suppose no matter about what point we are conserving angular momentum, we always use velocity of COM and MoI of COM of the object. (P.S.--if there are more that one objects, I write different mvr + Iω terms for the different COM of different objects in the system)
  • I always conserve angular momentum about a point where external torque is 0.
Hence observing the points above, in question (2), I conserved momentum about centre of the ring.
That becomes :
mvr=mv1r+mr2ω : v1 is the velocity of bullet after it has embedded in the loop and ω is the common angular speed.
..OK, now I think I figured out my mistake..
I think I incorrectly built a relationship b/w v1 and ω as v1=ωr, which I now think is not correct.
But now I can't figure out the relationship b/w the above two variables.
Related to Confusion regarding application of Conservation of Momentum
1. What is the Conservation of Momentum?
The Conservation of Momentum is a fundamental principle in physics that states the total momentum of a closed system remains constant over time, regardless of any external forces acting on the system. In other words, the total momentum before a collision or interaction is equal to the total momentum after the collision or interaction.
2. How is the Conservation of Momentum applied in real-life situations?
The Conservation of Momentum is applied in various real-life situations, such as collisions between objects, rocket propulsion, and ballistics. It is also used in industries like engineering, aviation, and transportation to design safe and efficient systems.
3. What are some common misconceptions about the Conservation of Momentum?
One common misconception is that momentum is always conserved in every situation. However, this principle only applies to closed systems where there are no external forces acting on the system. Another misconception is that the mass of an object affects its momentum, when in reality, it is the object's velocity that plays a crucial role.
4. Can the Conservation of Momentum be violated?
No, the Conservation of Momentum is a fundamental law of physics, and it has been extensively tested and proven to hold true in all situations. However, in certain situations, it may appear as though momentum is not conserved due to external forces that are difficult to measure or account for.
5. How is the Conservation of Momentum related to other laws of physics?
The Conservation of Momentum is closely related to other laws of physics, such as the law of inertia, Newton's laws of motion, and the law of conservation of energy. These laws all work together to describe the behavior of objects in motion and the interactions between them.
9K
