Hi there I am trying to get into topology
I am looking at the poincare conjecture
if a line cannot be included
as it has two fixed endpoints
by the same token
isn't a circle a line with two points? that has just be joined together
so by the same token the circle is not allowed?
Can i get a clarification
So you want to get into topology by one of the most complicated theorems topology has to offer? Ambitious plan. Good luck!
A line has a boundary, yes, and the Poincaré conjecture is a statement for objects without a boundary.
shiv23mj said:
by the same token
Which two points? They aren't anymore after you glued them together. Forgotten. Lost. Gone.
And lost its boundary when glued together.
The circle is allowed in the one-dimensional case. However, the statement sounds a bit stupid in this case because it becomes almost trivial: Every one-dimensional closed manifold of the homotopy type of a circle is homeomorphic to the circle. It means: any closed line without any crossings can (topologically) be seen as a circle.
The Poincaré conjecture (now theorem) is about specific topological objects (compact, simply connected, three-dimensional manifolds without boundary) and a criterion when two of them are topologically equivalent, namely to a 3-sphere, the surface of a four-dimensional ball.
The key is to understand what topological equivalent means. It basically means a continuous deformation that can be reversed. Not allowed are cuts, e.g. creating holes. That is why topologists consider a mug and a donut to be the same thing:
The Poincare conjecture says, that every compact, connected 3 - manifold (without boundary) which has trivial fundamental group, is homeomorphic to the 3-sphere.
Thus you must learn the concepts of homeomorphism, manifold, compactness, connectedness, and fundamental group, to even understand the statement.
I recommend reading the book Algebraic topology, an introduction, by William Massey, at least the first two chapters. You will find there most of the proof of the 2 dimensional analogue of the Poincare conjecture, already very instructive and interesting.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid.
I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem:
Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
