MHB Confusion with variables when solving a recurrence equation
The discussion revolves around solving a recurrence equation of the form T(n) = T(km) and determining its growth rate. The user is attempting to show that T(n) = Θ(n²) but is confused about the relationship between the variables m and n. They derive a pattern indicating that the leading term is m², yet struggle to connect m, which is dependent on n, to the overall function. A response clarifies that the recurrence relation behaves like a constant sequence for m ≥ 1, suggesting that the user may need to reassess their approach to the problem. Understanding the dependency between m and n is crucial for accurately establishing the growth rate of T(n).
JimmyK
If I have a recurrence equation of the following form:
$$T(n) = T(km) = a, m = 1$$
$$T(n) = T(km) = T(k) + T(k(m-1)) + cn, m > 1$$
Where a is simply a constant, and k is an integer constant > 0.
Now I begin substituting to find the pattern:
$$T(k) = a$$
$$T(2k) = a + [a] + c2k$$
$$T(2k) = 2a + 2ck$$
$$T(3k) = a + [2a + 2ck] + c3k$$
$$T(3k) = T(3k) = 3a + 5ck$$
$$T(4k) = a + [3a + 5ck] + c4k$$
$$T(4k) = 4a + 9ck$$
So it looks like the solution is:
$$T(n) = T(mk) = ma + ((\sum\limits_{i=1}^mi)-1)ck$$
$$T(n) = T(mk) = ma + (\frac{m}{2}(m+1)-1)ck$$
Now what I want to do is show that $$T(n) = \Theta(n^{2})$$
I can see in my solution that expanding it out, we end with a leading term of: $$m^{2}$$
Now my problem is, I have myself completely confused due to the variable names. T(n) = T(mk) and then the leading term is m^2, but I want to show that T(n) = Theta(n^2) and I don't think I've fully shown that because while m is dependent on n, it's not n. Any explanation of how I go about relating the two would be appreciated.
$$T(k) = a$$
Hi marobin, :)
It seems that your recurrence relation is in fact a constant sequence since \(T(n) = T(km)=a\mbox{ for }m\geq 1\).
Kind Regards,
Sudharaka.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
