Confussed about transit and subsequent transits
  • Thread starter leonne
  • Tags
    Transit
In summary, to calculate the time between subsequent transits of New Sol by New Earth, we need to use Kepler's third law to find the orbital period of New Earth and then use this value to calculate the time between transits. The duration of each transit would depend on the relative sizes and distances of the two objects, and could be calculated using the distance formula and the velocity of New Earth, which can also be calculated using the orbital period. It is important to use appropriate formulas and units in these calculations.
leonne
191
How long is it between subsequent transits of New Sol by New Earth
How long does each transit last? Assume that the transit is central, i.e. the
projected path of the planet goes right over the center of the star
Rp=(vp+vs)(t2-t1)(1/2)
Not sure which problem goes with the formula, i thought it would go with how long transit last but got the answer as 427s which seems way to fast also the second problem says that i=90 but formula does not have an i so does it go with the first one or neither?
Hello! I would like to clarify and provide some information regarding your questions.
Firstly, the formula you have provided is used to calculate the radius of a planet's orbit (Rp) based on the velocities of the planet (vp) and the star (vs) and the time between two observations (t2-t1). This formula is not directly applicable to the question about the duration of transits.
To calculate the time between subsequent transits of New Sol by New Earth, we need to know the orbital period of New Earth (how long it takes to complete one orbit around New Sol). This can be calculated using Kepler's third law: P^2 = (4π^2/G)(a^3), where P is the orbital period, G is the gravitational constant, and a is the semi-major axis of the orbit.
Once we have the orbital period of New Earth, we can use it to calculate the time between subsequent transits, which would be equal to the orbital period itself.
As for the duration of each transit, it depends on the relative sizes and distances of New Sol and New Earth. If we assume that the transit is central, meaning the projected path of New Earth goes right over the center of New Sol, then the duration of each transit would be equal to the time it takes for New Earth to move from one side of New Sol to the other, which can be calculated using the formula d=vt, where d is the distance between the two objects and v is the velocity of New Earth.
The velocity of New Earth can be calculated using the formula v=2πr/P, where r is the distance between New Earth and New Sol (which would be the sum of their radii) and P is the orbital period of New Earth.
I hope this helps clarify the questions and provides a starting point for solving them. Remember to always use appropriate formulas and units in your calculations. Good luck!
Related to Confussed about transit and subsequent transits
1. What is transit in the context of science?
Transit refers to the passage of a celestial body, such as a planet or moon, in front of another celestial body, as observed from a third body. This is commonly used in astronomy to study and track the movements and characteristics of planets and other objects in our solar system and beyond.
2. How does transit occur?
Transit occurs when a celestial body moves in front of another body as seen from a third body. This can happen when the orbits of these bodies align in a specific way. For example, when a planet orbits around a star, it can pass between the star and the observer, causing a transit event.
3. What is the significance of studying transits?
Studying transits can provide valuable information about the characteristics of celestial bodies, such as their size, composition, and orbital patterns. This information can help scientists better understand the formation and evolution of our solar system and other planetary systems.
4. How are transits observed and measured?
Transits are typically observed using telescopes and other instruments that can detect changes in light and other forms of radiation. By measuring the changes in brightness and other characteristics of the transiting body, scientists can gather data and make calculations to determine its properties.
5. Can transits have any impact on Earth?
Transits do not have any direct impact on Earth, as they are simply a natural occurrence in the universe. However, studying transits can help us better understand the potential for other celestial bodies to have an impact on Earth, such as asteroids or comets that may come into our solar system and potentially cause a collision.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
  • Science Fiction and Fantasy Media
9K
