Conical diffuser calculation using Bernoulli's Equation
In summary, the Bernoulli equation states that the pressure (Z) at a point is equal to the sum of the pressures (Z1+Z2) at two nearby points that are in hydrostatic equilibrium with the pressure at that point. The equation can be solved for Z1 and Z2 if you know the velocities and the pressures at the two points.
Michael V
28
The following information applies to a conical diffuser:
Length = 750 mm
Inlet diameter = 100 mm
Outlet diameter = 175 mm
Water flow = 50 l/s
Pressure at inlet = 180 kPa
Friction loss = [itex]\frac{k(V_{1} - V_{2})^{2}}{2g}[/itex] where k = 0.15
Calculate the pressure at exit. (10)
The same diffuser is then installed in a vertical pipeline where the flow is now downward and the quantity of water flow is to be double the above flow. The inlet pressure in the diffuser inlet (smaller diameter) is 150 kPa. Consider friction loss and calculate the pressure at the exit of the
diffuser. (10)
Bernoulli's Equation : [itex]Z_{1}+\frac{P_{1}}{ρg}+\frac{V_{1}^{2}}{2g}[/itex] = [itex]Z_{2}+\frac{P_{2}}{ρg}+\frac{V_{2}^{2}}{2g}+H_{loss}[/itex]
The 1st part of the question is not a problem where [itex]Z_{1}[/itex]= [itex]Z_{2}[/itex]. The problem I'm having is when it becomes vertical does [itex]Z_{1}[/itex]or [itex]Z_{2}[/itex] = 0.75m.
What do the symbols r1 and r2 represent in your equation, and what are they doing there?
Sorry, Pr is pressure.
To see what to do about Z1 and Z2, consider the simpler case where the flow rate is zero, so all you have is hydrostatic equilibrium. Z1 and Z2 will be the same values when you have flow.
Chet
So what happens when there is flow? Please could just have a look at my answer that's attached. Thanks.
  • April 2011 Q1.pdf
When there is flow, you just add the velocity and friction terms back into the equation. For hydrostatic equilibrium, if p1 is the pressure at the top and p2 is the pressure at the bottom, and z1 is the height of the top above the bottom datum, while z2 is the height of the bottom datum (z2 =0), Then the pressure at p2 would have to be higher than the pressure p1. So
p2 = p1 + ρg (z1 - z2)
So p1 + ρgz1 = p2 +ρgz2
This should automatically tell you what to use for z1 and z2 in the flow problem.
In your calculations for part 1, you made an error in calculating the velocities. They are a factor of 100 smaller.
Likes 1 person
It seems to me also that you are using the wrong units for pressure in the equation. You are substituting kPa, but it should be expressed in Pa.
Its starting make sense now, I was just struggling with where the bottom datum should be but I can see it has nothing to do with flow rate or its direction.
Thank you so much for your time.
This is great news Michael. Sometimes stuff like this can drive you crazy. Keep up the good work.
Chet
Related to Conical diffuser calculation using Bernoulli's Equation
1. How is Bernoulli's Equation used in conical diffuser calculations?
Bernoulli's Equation is used in conical diffuser calculations to determine the pressure and velocity changes that occur as a fluid flows through a conical-shaped pipe. This equation states that the sum of the pressure, kinetic energy, and potential energy of a fluid remains constant throughout its flow, assuming there is no energy loss due to friction or heat transfer.
2. What are the key parameters needed for conical diffuser calculations using Bernoulli's Equation?
The key parameters needed for conical diffuser calculations using Bernoulli's Equation include the inlet velocity and pressure, the outlet velocity, the angle of the conical diffuser, and the fluid density. These parameters can be measured or calculated based on the specific design and operating conditions of the conical diffuser.
3. How is the velocity profile of a fluid in a conical diffuser determined using Bernoulli's Equation?
The velocity profile of a fluid in a conical diffuser can be determined by solving Bernoulli's Equation at different points along the conical diffuser. The equation can be rearranged to solve for the velocity at each point, taking into account the changes in pressure and potential energy as the fluid flows through the varying cross-sectional area of the diffuser.
4. Can Bernoulli's Equation be used for all types of fluids in conical diffusers?
Bernoulli's Equation can be used for incompressible fluids, such as water, in conical diffusers. However, it may not be accurate for compressible fluids, such as air, as these fluids can experience significant changes in density and pressure as they flow through the diffuser.
5. Are there any limitations to using Bernoulli's Equation for conical diffuser calculations?
While Bernoulli's Equation can provide a good estimate of fluid behavior in conical diffusers, it does have some limitations. It assumes that the flow is steady, incompressible, and inviscid (no friction). In reality, there may be some energy losses due to friction and other factors that are not accounted for in the equation.
