Conical pendulum circular motion question
In summary, the angle swung out of a Chair-o-plane ride is determined by the balancing forces of weight, tension, and angular velocity. The equation does not depend on mass, but the size of the occupant affects the radius of the equation.
Shanyn
By resolving forces horizontally and vertically and using Newton's second Law, find an expression for the angle swung out of a Chair-o-plane ride.
Im just not really sure how to resolve the forces vertically and horizontally.
So far I know that forces acting on the chair are its own weight, mg and the tension in the chair, T.
Also that
T cos ѳ = mg
a= rω^2 ( ω being angular velocity).
Force causing the motion = F = mrω^2
= ma << Newtons second law
and horizontally T sin ѳ = mrω^2
that's ok.does not that give you
tanα=r(ω2)/g
Yeah, is that vertical or horizontal.?
with vertical.
So is that expression for the angle swung?
yes, but if the situation is much different from what you telling ,there can be changes.
Cool thanks. :)
That's the situation, the full questions are in a chair-o-plane 1. will a child swing out at a greater angle than a much heavier adult? 2. Will people on the inside swing out at the same angle as those on the outside? 3. Will empty chairs be a problem? and 4. What will happen as the speed increases. So by resolving forces horizontally and vertically to find the expression for the angle swung out we need to answer those four question. :)
you can predict it from the formula just written which does not depend on mass.
I think it is easy to get mixed up if you don't keep track of what you've done and what you know. It can help to draw the pictures of what is happening - you want one overhead and another from the side.
You have already noticed: [itex]T\sin(\theta)[/itex] is the horizontal unbalanced (tension) force ... which must be the centripetal force. [itex]T\cos(\theta)[/itex] is the balanced vertical component ... so you have two equations with two unknowns. Number them.
1. [itex]T\cos(\theta)=mg[/itex]
2. [itex]T\sin(\theta)=mr\omega^2[/itex]
The trouble is that you have to deal with trig functions right?
But it solves itself - you can do it blindly: solve for T in your first equation ([itex]T=mg/ \cos(\theta)[/itex], then substitute into the second one ... realize that sin/cos=tan. OR just divide the two equations directly - the T cancels out.
Now you just need the inverse tangent.
Keep these things straight and the rest will follow [note: I took too long and you had other answers :) ]
Thanks so much this has been the biggest help!
Also how could I show that a heavier person will swing out at a greater angle than a small child if the equation cuts out mass. Does that mean that the weight won't affect the angle swung.?
That's what it means - when the equation for angle does not include some factor - like temperature or color or (ahem) weight, then we say that the angle does not depend on that factor.
Ok thank you so much, I think I can finish it now. :)
However - the size of the chair's occupant will affect that r in your relation: it gets smaller.
Can you see how?
Umm not really, doesn't r= l sin theta. So how does the weight of the occupant affect r.? :)
Didn't say "weight of the occupant", I said "size" ... there's a difference ;)
Forinstance: on a regular swing that just goes back and forth, the swinging is faster for an adult than it is for a child on the same swing. It's also faster for the child if she stands up.
I don't know if you are expected to take this effect into account ... but it should be worth bonus marks if not.
FAQ: Conical pendulum circular motion question
What is a conical pendulum?
A conical pendulum is a pendulum that swings in a circular motion rather than back and forth. It consists of a weight attached to a string that is suspended from a fixed point. The weight moves in a circular path due to the tension in the string and the force of gravity.
What is circular motion?
Circular motion is the movement of an object along a circular path. In this type of motion, the object's speed and direction constantly change, but the object remains a fixed distance from a central point. This motion is described by the object's angular velocity and centripetal acceleration.
What factors affect the period of a conical pendulum?
The period of a conical pendulum is affected by the length of the string, the mass of the weight, and the angle at which the string is suspended. The period is also affected by the force of gravity and the strength of the tension in the string.
How is the tension in the string related to the weight and angle in a conical pendulum?
The tension in the string is directly proportional to the weight of the object and the cosine of the angle at which the string is suspended. This means that as the weight increases or the angle decreases, the tension in the string will also increase.
What is the relationship between the period and the length of a conical pendulum?
The period of a conical pendulum is directly proportional to the square root of the length of the string. This means that as the length of the string increases, the period will also increase, but at a slower rate. This relationship can be described by the equation T = 2π√(L/g), where T is the period, L is the length of the string, and g is the acceleration due to gravity.
