MHB Conics- Word problem with ellipses.
The problem involves finding the height of a semi-elliptical bridge with a maximum height of 3m and foci located 4m from the center. Given values are b=3 and c=4, leading to a calculation of a=5 using the equation a^2 = c^2 + b^2. The discussion clarifies that "2m from the edge" refers to 2m from a vertex, resulting in an x-coordinate of ±3. To find the height at this point, the equation of the ellipse can be used to determine the corresponding y-coordinate.
Kyriakos1
Hi. I am given the following problem. A small bridge is shaped like a semi-ellipse. Given that its maximum height is 3m and that its foci are located 4m from the centre find the height of the bridge at a distance of 2m from its edge.
So the problem give me the values b= 3 and c=4. With this we can find a. a^2= c^2 + b^2. 16 + 9 = 25 so a = 5. From there though I am stuck.. what does 2m from the edge represent? 2m away from from vertices (-5,0) and/or (5,0)? and how do I find the height if that is the case?
Mathematics news on Phys.org
Hi Kyriakos, and welcome to MHB! Yes, 2m from the edge must mean 2m from a vertex. So the $x$-coordinate will be $\pm3$.
You know that $a=5$ and $b=3$, so you should be able to write down the equation of the ellipse. Then you want to find the $y$-coordinate (the height) when $x = \pm3$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
