Conjecture about parallel and series circuits
In summary, the conversation discusses the possibility of combining n resistors in various ways to find the equivalent resistance of a device with two terminals. The conjecture is that n=5 is the lowest for which this strategy cannot be applied. The conversation also mentions potential proofs and counterexamples for n<5 and n=6+.
bcrowell
Staff Emeritus
Insights Author
431
If we have n (possibly unequal) resistors, we can combine them in various ways to produce a device with two terminals. In many cases, the equivalent resistance of this device can be found by repeatedly breaking the circuit down into parallel and series parts. Conjecture: n=5 is the lowest for which a circuit exists such that this strategy cannot be applied.
Can anyone prove this, or provide a counterexample for n<5?
What do you mean "have n resistors". Are you trying to find equivalent resistance between two points? The simplest one I can think of right now is the resistor cube but that is n=12. Can you show me one for n=5?
n=5 is the Wheatstone bridge circuit.
Shouldn't be that hard to prove. With n=4 you have 4 elements. Connect two together, and you get 2 resistors in series. Now with the 3rd resistor, you can either put it in series again, or connect it in between the first two to make a T.
If you do the first, then you have 3 resistors in series. The forth one must either go at the ends or somewhere in between, making either 4 or 3 or 2 resistors in series (effectively shorting out other resistors). This can be solved using equivalent combination.
If you use the 3rd element to make a T, then the fourth must either be in parallel with two other resistors (three possibilities) or it can go in series and short one resistor out. This can also be solved using equivalent combination.
So yeah, this is a sketch of proof for n=4. With n=3 it's easier (the proof is actually inside the proof for n=4) and n=2 and n=1 are trivial.
For n=6+ you can find a counterexample, such as a Wheatstone bridge with resistors attached in series.
I cannot provide a definitive answer to this conjecture without further information or experimentation. However, I can offer some thoughts and considerations.
Firstly, the concept of parallel and series circuits is well-established in electrical engineering and has been extensively studied and tested. The idea of combining resistors in different configurations to achieve a desired resistance is a common practice.
Secondly, the statement "n=5 is the lowest for which a circuit exists such that this strategy cannot be applied" is a bold claim and would require significant evidence to support it. It would be helpful to know the specific criteria or conditions under which this conjecture was made, as well as any assumptions that were made in the process.
Furthermore, it is important to note that the behavior of electrical circuits can be complex and unpredictable, especially when dealing with non-ideal components. As such, it is possible that there could be a circuit with n<5 resistors that cannot be simplified using the parallel and series strategy. However, this would likely be a rare and specific case and not a general rule.
In conclusion, while the conjecture presented is interesting, it is important to approach it with caution and continue to explore and test it further before making any definitive statements or conclusions. As with any scientific theory, it is always open to revision and refinement as new evidence and insights are gained.
FAQ: Conjecture about parallel and series circuits
What is the difference between a parallel and series circuit?
A parallel circuit is a type of electrical circuit where the components are connected in such a way that there are multiple paths for the current to flow. In contrast, a series circuit is a circuit where the components are connected in a single loop, with only one path for the current to flow.
Can you explain the concept of resistance in parallel and series circuits?
In parallel circuits, the total resistance decreases as more components are added because the current has multiple paths to flow through. In series circuits, the total resistance increases as more components are added because the current has to flow through each component in succession, resulting in a cumulative resistance.
What is the effect of adding more components to a parallel or series circuit?
In a parallel circuit, adding more components will decrease the overall resistance and increase the total current flow. In a series circuit, adding more components will increase the overall resistance and decrease the total current flow.
How does the voltage change in parallel and series circuits?
In a parallel circuit, the voltage across each component is the same, while the total voltage is equal to the sum of the individual voltages. In a series circuit, the voltage across each component is different and the total voltage is equal to the sum of the individual voltages.
Can you give an example of a real-life application of parallel and series circuits?
A common example of a parallel circuit is a household electrical outlet, where multiple appliances can be plugged in and run simultaneously without affecting each other. A series circuit is often used in Christmas lights, where the bulbs are connected in a single loop and if one bulb is removed, the entire string will not light up.
