Connecting a glass dewar flask to a vacuum system
In summary, the conversation discussed the use of glass dewar flasks in vacuum systems and how they are connected and sealed. It was mentioned that there are various methods for creating a vacuum-tight bond between glass and metal, such as using glue or brazing. The specific method used may depend on the type of dewar and its intended use. It was also noted that glass labware is being phased out and replaced with more durable materials.
swooshfactory
63
I'm wondering how a glass dewar flask connects to a vacuum system, i.e. how is it vacuum sealed? Once it is sealed, I see how you can use appropriate flanges to pump out the, say, He gas, but how is a glask flask connected to this vacuum system?
Thanks.
My guess is that the glass and metal were brazed together. Someone else who understands the manufacturing process can correct this.
Zz.
There are probably a few ways of doing this. However, I wouldn't be too surprised if glue could be used.
Stycast and a few other glues can be used to make strong, vacuum tight bonds between different materials and works surprisingly well as long as one keeps the usual things in mind (expansion coefficients etc)
Er, glue? Even for UHV systems?
I suppose I can expect some sort of an epoxy, but I must admit I don't know of any glue that is UHV compatible.
Zz.
For Thermos bottles (the type you drink out of), the bottom of the flask ends in a small diameter glass tubing. Large glass lab dewars often have a large-bore (1", e.g.) glass tube, the better to pump down quickly and deeply. It often comes out of the side near the top, for convenience. The transition to the vacuum system is made by slipping over a special brass or stainless collar that has a compression fitting similar to those used to connect 3/8" copper water tubing into the angle stop valve under your bathroom sink. The compression seal is made by a rubber O-ring instead of a brass ferrule, with a little high-vacuum silicone grease to ensure a good seal. A length of flexible piping, which can be heavy-walled rubber or a stainless steel bellows, provides strain relief between the glass dewar and the valve at the input port to the vacuum pump. In the lab, the dewar is always connected. The Thermos bottle, on the other hand, is pumped down and then its little glass tube is heated with a torch, sealed, and broken free. In some Thermos bottles, you can remove the bottom and see this.
Of course more exotic systems are available to address special requirements.
BTW, glass labware started phasing out a half-century ago, due to its fragility and because highly skilled artisans are needed to produce it. Dewars are now made of fiberglass or metal, which are rugged and can be mass-produced.
I'm not sure if we're talking about the same thing. From reading the OP, I gather that this is an example of the type of connector that is in question:
http://www.mdcvacuum.com/DisplayProductContent.aspx?d=MDC&p=m.f.1.1.1
The glass to metal adapters are used in many situations, some time down to UHV level.
Zz.
Zz.
The OP talked about a glass dewar, so I assume he/she meant the type of glass helium dewar that is still often used for lab demonstrations of e.g. superfluidity and other low-temperature experiments.
Dewars of this type are not UHV, far from it (you have to pump out the isolation vacuum whenever you warm them up to room temperature).
Btw, stycast works quite well even for vacuum vessels immersed in liquid helium and the leak rate is quite low; I use it quite frequently.
FAQ: Connecting a glass dewar flask to a vacuum system
How do I connect a glass dewar flask to a vacuum system?
To connect a glass dewar flask to a vacuum system, you will need to use a vacuum adapter. This adapter is typically made of rubber and is designed to fit tightly around the neck of the dewar flask. Once the adapter is in place, you can connect it to the vacuum system using a hose or tubing.
Why is it important to connect a glass dewar flask to a vacuum system?
Connecting a glass dewar flask to a vacuum system is important because it allows for the removal of air and other gases from the flask. This creates a vacuum inside the flask, which is necessary for certain experiments and processes. It also helps to prevent the loss of volatile substances that may evaporate at room temperature.
Can any type of vacuum be used to connect a glass dewar flask?
No, not all types of vacuums are suitable for connecting a glass dewar flask. The vacuum system should be able to reach a high level of vacuum, typically around 10^-3 torr, to effectively remove gases from the flask. It is important to use a vacuum pump specifically designed for laboratory use.
How do I maintain the connection between the glass dewar flask and the vacuum system?
The connection between the glass dewar flask and the vacuum system should be maintained by regularly checking for any leaks. This can be done by applying a vacuum gauge to the system and ensuring that the desired level of vacuum is reached and maintained. It is also important to regularly check and replace any damaged or worn out parts, such as the vacuum adapter or tubing.
Is there a specific way to disconnect the glass dewar flask from the vacuum system?
Yes, there is a specific way to disconnect the glass dewar flask from the vacuum system to avoid damaging the flask or releasing any harmful substances. First, turn off the vacuum pump and allow the system to reach atmospheric pressure. Then, slowly and gently remove the vacuum adapter and any connecting tubing. Be sure to handle the flask with care to avoid any sudden changes in temperature that could cause it to crack.
