leafalling
- 1
Referring to the circuit, I need to verify this by PSpice simulation.
I have calculated gain parameter k = 2.5 when Rin = 0 and the current flow through the 0.5S(2 ohm) resistor = 0.5IoA, which is correct.
Firstly, I considered Io as a 1A DC current source in PSpice. Then, I have tried to connect the 4-terminal current-controlled voltage source in PSpice but I am not sure whether it is correct. Referring to the simulation result in PSpice, I also wondered why is there no current flow through the 2 ohm resistor (expected 0.5A here).
So, could anyone explain how to connect the 4-terminal current controlled voltage source in this case??
Thanks very much for your help!
