- 3,515
- 9,792
- TL;DR Summary
- I want to connect extra IPs to the internet on my server
I got a new server that I want to set up. It comes with 2 IPv4 and 1 IPv6. I'm new to these network settings and I have a hard time following what I need to do.
My ISP gives me this info about my IPs (not the real ones):
From the ISP dashboard I also created the following IPv6:
I did a first install and I couldn't make either the extra IPv4 or the IPv6 I created reachable from an outside computer. All I ended up achieving was connections on localhost only. Anyway, I ended up screwing everything and now I did a new install. This time I chose to add an extra interface (ens4) during the OS install, setting it up with my extra IPv4, hoping it would at least work with this address. Nope. Works locally but not from an outside computer.
Here is the info from my network:
What I did to test the connection was to use
I must admit I have a hard time following the terms "interface", "address", "route", etc., and what I really need to set up to accomplish what I want. I have no clue what the internal IP address is for and if it is useful to me. I played with netplan and ip and I prefer ip if possible.
Looking for help because not only search engines haven't been really helpful but the server is 3000 miles away and I can't kick it.
Code:
IP Address (main) 111.222.11.33
Netmask/Bitmask 255.255.255.0
Gateway 111.222.11.1
Resolver #1 115.225.111.88
Resolver #2 115.225.111.99
IP Address (extra) 111.222.22.44
Gateway 111.222.22.1
Resolver #2 115.225.111.88
IP Address (internal) 101.202.55.66
Netmask/Bitmask 255.255.0.0
Gateway 101.202.0.1
Resolver #1 N/A
Resolver #2 N/A
Link-local IPv6 Subnet
1234:5678:11:2222::/64
Code:
IP Address (created) 1234:5678:11:2222::1
Netmask/Bitmask 48
Gateway 1234:5678:11::1
Resolver #1 N/A
Resolver #2 N/A
Code:
username@hostname:~$ ss -lntu
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 0 0 127.0.0.53%lo:53 0.0.0.0:*
tcp LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:*
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:*
tcp LISTEN 0 128 [::]:22 [::]:*
username@hostname:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:16:ce:ce:97:8f brd ff:ff:ff:ff:ff:ff
altname enp0s3
inet 111.222.11.33/24 brd 111.222.11.255 scope global ens3
inet6 fe80::216:ceff:fece:978f/64 scope link
3: ens4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:16:e9:e9:cc:67 brd ff:ff:ff:ff:ff:ff
altname enp0s4
inet 111.222.22.44/24 brd 111.222.22.255 scope global ens4
inet6 fe80::216:e9ff:fee9:cc67/64 scope link
username@hostname:~$ ip r
default via 111.222.22.1 dev ens4 proto static
default via 111.222.11.1 dev ens3 proto static
111.222.22.0/24 dev ens4 proto kernel scope link src 111.222.22.44
111.222.11.0/24 dev ens3 proto kernel scope link src 111.222.11.33
nc -l4 xxx.xxx.xxx.xxx 8493
to listen to the IPv4 address and open a telnet xxx.xxx.xxx.xxx 8493
on another machine. Even though the ss -lntu
command gives the same output for the sockets (only the IP address differs), only the main IP address can communicate outside the localhost.I must admit I have a hard time following the terms "interface", "address", "route", etc., and what I really need to set up to accomplish what I want. I have no clue what the internal IP address is for and if it is useful to me. I played with netplan and ip and I prefer ip if possible.
