Connecting the Keystone Equation and Derivatives
  • MHB
  • Thread starter jedson303
  • Tags
    Derivatives
In summary, the keystone of calculus is the limits equation, which shows how it really does work. This equation is easy to understand, but the derivative trick is a cheap trick that follows logically from the definition.
jedson303
Here's a question. This formula seems to be the keystone of calculus.
View attachment 644That seems to be what the calculus books say, and it makes sense to me, as a rank beginner. This equation is what makes the seeming magic of defining the slope of a dimensionless point on a curved slope possible. And doing that seems to be the major hurdle to opening up things for a calculus. But almost immediatly we are taught to make derivatives by a totally different method -- reducing the exponant by one, etc. So that, for exmple 2x^3 becomes 6x^2 etc. Well, that is of course lots easier. But where is the connection? How does one get from that magical limits equation (which shows how it really does work) to the the cheap trick? (Not that I am necessarily against cheap tricks.)
That is an excellent question, and shows that you are thinking in the right way for a mathematician! Too often, calculus is taught as though it is just a box of tricks, when in fact these "tricks" follow logically from the definitions.
Take your example of the function $f(x) = 2x^3$. If you apply the "keystone" formula, then the derivative of this function at the point $x=a$ is $$f'(a) = \lim_{h\to 0}\frac{f(a+h)-f(a)}{h} = \lim_{h\to 0}\frac{2(a+h)^3 - 2a^3}{h}.$$ Now you have to do a bit of algebra, to calculate that $2(a+h)^3 = 2a^3 + 6a^2h+6ah^2+h^3.$ It follows that $$\frac{2(a+h)^3 - 2a^3}h = \frac{6a^2h + 6ah^2 + h^3}h = 6a^2 + 6ah + h^2.$$ Then as $h\to0$, the last two terms in that expression go to $0$ and you see that $$\lim_{h\to0}6a^2 + 6ah + h^2 = 6a^2.$$ So the derivative of $6x^3$ at $x=a$ is $6a^2.$ This is usually written in an abbreviated form by saying that the derivative of $6x^3$ is $6x^2.$
Tim Gower has something to say about this on his blog:
http://gowers.wordpress.com/2012/11/20/what-maths-a-level-doesnt-necessarily-give-you/
Moderator edit: This interesting blog sparked interest in another discussion, which I have moved http://www.mathhelpboards.com/f9/counter-intuitive-phenomena-math-physics-3637/ in order to keep this discussion on topic.
OK, Opalg. I see how that works. It does connect. Thanks.
Let's say we want to find the derivative of $\displaystyle \begin{align*} f(x) = k\,x^n \end{align*}$, where k is a constant and n is a positive integer. Then we have
[tex]\displaystyle \begin{align*} f'(x) &= \lim_{h \to 0}\frac{f(x + h) - f(x)}{h} \\ &= \lim_{h \to 0}\frac{k\left( x+ h \right)^n - k\,x^n}{h} \\ &= \lim_{h \to 0}\frac{ k \sum_{r = 0}^n{ \left[ {n\choose{r}} x^{n-r} h^r \right] } - k\,x^n }{h} \\ &= \lim_{h \to 0}\frac{k\,x^n + k\sum_{r = 1}^n{\left[ {n\choose{r}} x^{n-r} h^r \right] } - k\,x^n }{h} \\ &= \lim_{h \to 0}\frac{ k\sum_{r = 1}^n{ \left[ {n\choose{r}} x^{n-r} h^r \right] } }{h} \\ &= \lim_{h \to 0} k\sum_{r = 0}^n{ \left[ {n\choose{r}} x^{n-r} h^{r-1} \right] } \\ &= \lim_{h \to 0}\left\{ n\,k\,x^{n-1} + k\sum_{r = 2}^n{ \left[ {n\choose{r}}x^{n-r}h^{r-1} \right] } \right\} \\ &= n\,k\,x^{n-1} \end{align*}[/tex]
The result easily extends to other types of powers, but might need knowledge of the chain rule or other rules.
I'm going back to review the Infinite sequences and summation notations, to better follow all the calculations. But I can see what you are doing. This way you don't just prove the validity of a function with a specific value, but show why this holds for all values of that function. How, in other words, it can be deduced from the "keystone" formula, and then used as a valid rule. Which is what I asked. Interesting.
Jedson
Jedson
It's not an infinite sequence, or an infinite series for that matter. It's a particular finite series called the Binomial Theorem or Binomial Expansion.
I guess I didn't understand what you were doing. I'll review the binomal therum and see if I can follow the computation. Then try to understand what it actually means.
jedson
FAQ: Connecting the Keystone Equation and Derivatives
What is the Keystone Equation?
The Keystone Equation is a mathematical formula that relates the concentration of a reactant to the rate of reaction in a chemical reaction. It is used to determine the rate at which a reactant is consumed or a product is formed.
How do derivatives relate to the Keystone Equation?
Derivatives are used to find the rate of change of a function at a specific point. In the Keystone Equation, derivatives are used to find the rate of reaction at a particular concentration of a reactant.
Can the Keystone Equation be applied to all chemical reactions?
No, the Keystone Equation is specifically used for first-order reactions, where the rate of reaction is directly proportional to the concentration of a single reactant.
How is the Keystone Equation useful in chemical kinetics?
The Keystone Equation allows scientists to predict the rate of reaction at different concentrations of a reactant. This is important in understanding the kinetics of a chemical reaction and can help in optimizing reaction conditions.
Can the Keystone Equation be applied to reactions with multiple reactants?
Yes, the Keystone Equation can be modified to apply to reactions with multiple reactants. This is done by considering the concentration of each reactant separately and then applying the equation to the overall rate of reaction.
