Connection 1-forms to Christoffel symbols
In summary, the Christoffel symbols for an orthonormal basis in spherical coordinates can be computed using the connection one-forms and the relation ##\omega^i_j = \Gamma^i_{jk} \sigma^k##. Due to the dimensionless nature of the connection one-forms, the Christoffel symbols must have a physical dimension of ##\mathsf L^{-1}## and thus are proportional to ##1/r##, the only dimensionful parameter in the system.
WendysRules
37
Let the metric be defined as ##ds^2=dr^2+r^2d\theta^2+r^2\sin^2\theta d\phi^2##
Through some calculations, we then see that our connection one forms are ##\omega_{12} = -d \theta## and ##\omega_{21}= d\theta##, ##\omega_{13} = -sin\theta d \phi## and ##\omega_{31} = sin\theta d\phi## ##\omega_{23}=cos\theta d\phi## and ##\omega_{32} = -cos\theta d\phi## (for work, look at: https://www.physicsforums.com/threa...ctor-in-spherical-coords.903231/#post-5687781)
We can then use the fact that ##\omega^i_j = \Gamma^i_{jk} \sigma^k## to compute the Christoffel symbols.
Notice that if ##i = j## all the Christoffel symbols will vanish due to ##\omega^i_i = 0## thus, right off the bat we know that ##\Gamma^1_{11} = \Gamma^1_{12} = \Gamma^1_{13} = \Gamma^2_{21} = \Gamma^2_{22} = \Gamma^2_{23} = \Gamma^3_{31} = \Gamma^3_{32} = \Gamma^3_{33} = 0##
With metric compabitibility, we know that ##\Gamma^i_{jk} = -\Gamma^i_{kj}## thus... ## \Gamma^1_{21} = \Gamma^1_{31} = \Gamma^2_{12} = \Gamma^2_{32} = \Gamma^3_{13} = \Gamma^3_{23} = 0##
So onto the ones we can calculate, ##\omega^1_2 = -d \theta = \Gamma^1_{21} \sigma^1 + \Gamma^1_{22} \sigma^2 + \Gamma^1_{23} \sigma^3 = 0 + \Gamma^1_{22} r d\theta + \Gamma^1_{23} r\sin\theta d\phi##
The only way for this equation to be true is for##\Gamma^1_{22} = \frac{-1}{r} ## and ##\Gamma^1_{23} = 0 ## We then can set ##\Gamma^1_{32} = 0 ##
Next, ##\omega^1_3 = -sin\theta d \phi = \Gamma^1_{31} \sigma^1 + \Gamma^1_{32} \sigma^2 + \Gamma^1_{33} \sigma^3 = 0 + 0 + \Gamma^1_{33} r\sin\theta d\phi## therefore, we see that ##\Gamma^1_{33} = \frac{-1}{r}##Next, ##\omega^2_3 = cos\theta d\phi = \Gamma^2_{31} \sigma^1 + \Gamma^2_{32} \sigma^2 + \Gamma^2_{33} \sigma^3 = \Gamma^2_{31} dr + \Gamma^2_{33} r\sin\theta d\phi## To make this true, we then see that ##\Gamma^2_{31} = 0 ## and ##\Gamma^2_{33} = \frac{\cos\theta}{r\sin\theta} = \frac{\cot\theta}{r} ##
Which raises a red flag! I've never see a Christoffel symbol where we have that r in the denominator for ##\Gamma^{\theta}_{\phi \phi}## so if anyone can point out my error, i'd appreciate it.
Could it be that I'm so use to seeing people set r=const.=1 that I usually do not see the r?
Since your connection one-form is dimensionless (basically as a consequence of using an orthonormal basis), the physical dimension of your Christoffel symbols must be the inverse of the physical dimension of the corresponding ##\sigma^i##. For both ##\sigma^2## and ##\sigma^3##, the physical dimension is ##\mathsf L## and hence the corresponding Christoffel symbols must have physical dimension ##\mathsf L^{-1}##. This means the Christoffel symbols have to be proportional to ##1/r## as ##r## is the only dimensionful parameter you have.
Also note that what you are computing are the Christoffel symbols of the orthonormal basis you have chosen. I would reserve ##\Gamma^\theta_{\phi\phi}## etc for the Christoffel symbols in holonomic basis.
Likes WendysRules and lavinia
Could you explain this more?
I assume you mean the first part? I guess dimensional analysis is a concept more used in physics. Mathematicians would probably prefer to refer to it as a scaling property when ##r \to kr##. Under this transformation the connection 1-forms do not change, but the expressions for the dual basis vectors ##\sigma^2## and ##\sigma^3## do. In order to maintain the relation between the connection 1-forms, the dual basis vectors, and the Christoffel symbols, the Christoffel symbols ##\Gamma^i_{j2}## and ##\Gamma^i_{j3}## must scale as ##1/r##.
Likes lavinia
Thanks. I see now. Nice argument.
Related to Connection 1-forms to Christoffel symbols
What are connection 1-forms and Christoffel symbols?
Connection 1-forms and Christoffel symbols are mathematical concepts used in differential geometry and general relativity. Connection 1-forms are mathematical objects that describe how a vector field changes as you move along a curve, while Christoffel symbols are coefficients that relate to the curvature of a manifold.
How are connection 1-forms and Christoffel symbols related?
Connection 1-forms and Christoffel symbols are closely related, as the connection 1-forms are used to calculate the Christoffel symbols. The Christoffel symbols are derived from the derivatives of the connection 1-forms.
Why are connection 1-forms and Christoffel symbols important?
Connection 1-forms and Christoffel symbols are important in differential geometry and general relativity because they help us understand the curvature and properties of a manifold. They are also used in calculations for things like geodesics and the equations of motion in general relativity.
How are connection 1-forms and Christoffel symbols used in general relativity?
In general relativity, connection 1-forms and Christoffel symbols are used to define the connection on a spacetime manifold. This connection describes how objects move through spacetime and is crucial in understanding the effects of gravity.
Are there any real-world applications of connection 1-forms and Christoffel symbols?
While connection 1-forms and Christoffel symbols are primarily used in mathematics and theoretical physics, they do have some real-world applications. For example, they are used in navigation systems to calculate the shortest path between two points on a curved surface, such as the Earth's surface.
  • Differential Geometry
