TerryW
- 14
I've run into a couple of problems with exercise 12.6 in MTW (attached).
At this stage, all I'm asking is for someone to give me answers to the following questions:
1. What are the Rα'β'γ'δ' in the primed co-ordinate system? and
2. What are the non-zero connection coefficients in the primed co-ordinate system?
I started with an Earth bound co-ordinate system fixed so that the x-axis runs from the centre of the Earth through the prime meridian at the equator and worked to get the co-ordinate transformations between (x' , y') and (x , y) and used -2GM/R2 for Rα1010 and GM/R2 for R2020. The results for R1'0'1'0' and R2'0'2'0' didn't turn out as I think they should.For my connection coefficients I ended up with
Γ1'0'0' = +ω2x' ,
Γ2'0'0' = -2ω2y'
Γ1'0'2' = -ω
Γ2'0'1' = +ωWhich didn't give a good result for the geodesic equation for y'.
I used the connection coefficients to calculate R1'0'1'0' and Rα2'0'2'0' and ended up with 2ω2 and -ω2 respectively which also doesn't look quite right.Can anyone put me on the right track here?RegardsTerryW
Γ1'0'0' = +ω2x' ,
Γ2'0'0' = -2ω2y'
Γ1'0'2' = -ω
