Consecutive numbers without using a 7 ?
  • Thread starter starfish99
  • Tags
    Numbers
In summary, the conversation discusses calculating the number of consecutive integers within a given range that do not contain the number 7. The speaker suggests subtracting 1/9 of the total numbers to account for numbers that do not start with 7. The conversation then delves into discussing restrictions on numbers in different positions and suggests a combinatorial approach to solving the problem. The final calculation is determined to be 90,000 minus 8x9x9x9 for the number of 5-digit numbers with a seven.
starfish99
28
Consecutive numbers without using a "7"?
I tried to calculate the number of consecutive integers between 10,000 and 99,999 that do not use the number 7. I got part of the way there.
There are 90,000 numbers(if you start with 10,000) and if you subtract 1/9 of 90,000 that will give you a total of 80,000 that don't begin with a seven. How do you handle the calculation of the the seven in the thousands, hundreds, tens and units place?
Mathematics news on Phys.org
Let me see if I understand this correctly. Say that you wanted to do the same, but do it for numbers in the range 0 to 9. Then the numbers that you are talking about are just: {1,2,3,4,5,6,8,9}, right? Or, if you are doing it from 10 to 99 the numbers 10,11,12,13,14,15,16,18, would all be in the set (I'm not saying these are all the numbers, just some) but the numbers 7,17,27,74 would not (again, there are more that aren't in the set, I just want to make sue I understand), correct?
You have a five digit number. Let's write it this way: a_4*10^4 + a_3*10^3 + a_2*10^2 +a_1*10^1 + a_0*10^0. Now, there are certain restrictions we have on the a_i's, right? What are they? For instance, none of them can be "7", right? Can you think of any other restrictions for any of the other numbers (consider a_4, in particular.) Now, given the restrictions on each a_i, how many possibilities are there for each a_i? That is, how many choices do you have for a_4, a_3,...,a_0?
Now do you see what to do? In other words, make this a completely combinatorial problem.
So a(4) can be any of eight numbers(1 thru 9) excepting 7 and a(3) a(2) a(1) and a(0) can be any of nine numbers (0 thru 9) excepting 7. The ans. is 90 000 minus 8x9x9x9.
Thank you
Sorry Robert1986
8X9X9X9 is the number of 5 digit numbers without a seven.
90 000 minus 8X9X9X9 is the number of 5 digit numbers with a seven.
Thanx again
I would approach this problem by first understanding the pattern and logic behind consecutive numbers. In this case, we are dealing with integers that increase by one from a starting number to an ending number. So, for example, if we start with 10,000, the next consecutive number would be 10,001 and so on until we reach 99,999.
To calculate the total number of consecutive integers without using the number 7, we can break it down into smaller parts. First, we can focus on the thousands place. We know that there are 9 possible digits that can be used in the thousands place (0-9), and we want to exclude the number 7. This leaves us with 8 options for the thousands place.
Next, we can consider the hundreds, tens, and units place. Again, we have 9 possible digits for each of these places, but we want to exclude the number 7. This leaves us with 8 options for each place.
Using this logic, we can calculate the total number of consecutive integers without using the number 7 as 8 x 8 x 8 x 8 x 8 = 32,768.
In summary, to calculate the total number of consecutive integers between 10,000 and 99,999 without using the number 7, we can use the formula (8^5), where 8 represents the number of options for each place and 5 represents the number of places. This results in a total of 32,768 consecutive integers without using the number 7.
FAQ: Consecutive numbers without using a 7 ?
What is the concept of consecutive numbers without using a 7?
The concept of consecutive numbers without using a 7 is to find a sequence of numbers where each number is followed by the next consecutive number, but without using the number 7 in the sequence.
How is this concept relevant in science?
This concept is relevant in science because it can be used in experiments or simulations to manipulate data and remove the number 7 from a sequence of numbers, allowing for more accurate results.
What are some examples of consecutive numbers without using a 7?
Some examples of consecutive numbers without using a 7 are: 1, 2, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15 and so on.
How is this concept useful in real-life situations?
This concept can be useful in real-life situations such as organizing data or creating numerical patterns without the interference of the number 7. It can also be used in games or puzzles where consecutive numbers are required.
Are there any other numbers that can be excluded from consecutive numbers?
Yes, there are many other numbers that can be excluded from consecutive numbers, such as 3, 5, 9, and so on. The concept of consecutive numbers without using a 7 can be applied to any number, depending on the purpose or context.
