MHB Consecutive vertical and horizontal transformations of a function
The discussion revolves around transforming the function f(x) = (2^x) + 1 through a series of specified transformations. The transformations include a vertical stretch by a factor of 8, a translation by the vector (1,4), and a horizontal stretch by a factor of 1/2. The user expresses confusion about the correct order of applying these transformations to arrive at the final function h(x). They initially applied horizontal transformations before vertical ones but did not achieve the textbook solution, which is h(x) = 4^(x+1) + 16x - 4. The thread highlights the importance of the sequence in which transformations are applied to obtain the correct result.
pluto1
Dear all,
I am stuck on this question:
"If f(x)=(2^x)+1, give in simplest terms the formula for h(x), which is obtained from transforming f(x) by
a vertical stretch, scale factor 8 relative to y=0
a translation by vector (1,4)
a horizontal stretch, scale factor 1/2 relative to x=0"
This is what I understand from the question:
A vertical stretch by scale factor 8 means h(x)= 8 f(x)
A translation by vector (1,4) means h(x)= f(x-1) + 4
A horizontal stretch by scale factor 1/2 means h(x)= f(1/2x)
Where the horizontal shift is applied prior to the horizontal stretch.
This gives me
h(x)= 8 ((2^(1/2 x-1) + 1/2 x - 1))+ 4
h(x)= 2^(2x-2) + 16 x - 4
h(x)=4^(x+1)+16x-4 according to the solutions at the back of my textbook. I would really appreciate some help. Thank you so much in advance.
Mathematics news on Phys.org
In what order are you doing these transformations?
I applied the horizontal changes before the vertical changes, with the translation by -1 prior to the stretch by 1/2
I just tried the opposite with all the vertical changes first but that does not give me the correct solution either
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
