Spathi
- 7
- TL;DR Summary
- Not only the concentration of CO2 is important, but also the rate of its change (with the current rate, the ecosystems do not have time to react), and also that positive feedback can work now (the ocean, heating up, releases steam, which is also a greenhouse gas). But I would like to see these points explained in more detail.
It is known, that due to global warming, the average temperature on Earth over the past 100 years has increased by 1.2 degrees. At the same time, I heard that earlier the temperature of the Earth was 7 degrees higher than the current one.
I do not deny the danger of global warming, because I have seen the information that not only the concentration of CO2 is important, but also the rate of its change (with the current rate, the ecosystems do not have time to react), and also that positive feedback can work now (the ocean, heating up, releases steam, which is also a greenhouse gas). But I would like to see these points explained in more detail.
How probable is this scenario considered?
https://www.pnas.org/doi/full/10.1073/pnas.1910114117
And what here means “business-as-usual climate scenario” in this article?
I also heard that 500 million years ago the concentration of CO2 was 6000 ppm, and with this concentration, a man suffocates. Is it true?
Specifically, 3.5 billion people will be exposed to MAT ≥29.0 °C, a situation found in the present climate only in 0.8% of the global land surface, mostly concentrated in the Sahara, but in 2070 projected to cover 19% of the global land
