Conservation Laws and Collisions with a Spring
In summary, the conversation discusses a problem involving two blocks with mass M1 and M2, initially moving at different speeds, and a spring with negligible mass and a spring constant k. The conservation laws of energy and momentum are conserved during the collision, and equations are written to express this conservation when the spring is compressed a distance X. The final speeds of the blocks are determined when the masses are equal and the spring reaches a maximum compression of L. The final speeds of the blocks are also calculated when the spring is removed and the masses are equal.
nibbles198
A first block with mass M_1 is initially moving with a speed V_o to the right and a second block with mass M_2 is at rest. The second block has a spring attached to it. The spring has negligible mass. The spring has a spring constant k. The horizontal surface is frictionless. (Note: the spring is facing the first block)
a) What quantities are conserved throughout the collision?
b) Write equations that express the conservation laws during the collision when the spring is compressed a distance X.
c) Now redo part b) and assume that the masses are both equal to M
d) Solve the equations in part c) for the speeds of the blocks V_1 and V_2 during the collision when the spring is compressed a distance X. Again assume the masses are equal.
e) Now assume that the spring reaches a maximum compression L during the collision. Plot V_1 and V_2 vs the compression of the spring, X (masses are equal).
f) After the collision what are the final speeds of the two blocks? (masses are equal)
g) Now remove the spring from the second block and consider the collision again, assuming that the two masses are equal. With the same initial speeds solve for the final speeds of the two blocks.
a)
Energy and Momentum
b)
Here's where I get confused (yes, this early in the problem unfortunately). I used:
.5*k*x^2 = .5*M_1*(V_o)^2 and
.5*k*x^2 = .5*M_2*(V_final)^2
Since the first mass should stop after hitting the spring and the second should gain all of the energy of the system in Kinetic energy. So these two problems are basically saying that the Potential energy of the spring = the kinetic energy of the first mass = the final kinetic energy of the second mass. But...it seems like this is wrong, since part d) asks for the speeds of the blocks V_1 and V_2 during the collision.
So I guess my real question here is, do the two equations I set up express the conservation laws during the collision when the spring is compressed a distance X?
Thank you in advance.
welcome to pf!
hi nibbles198! welcome to pf! :wink:
(are you a rabbit? I'm a goldfish! :smile:)
(try using the X2 and X2 icons just above the Reply box :wink:)
no, since (b) asks for the conservation laws (btw, that includes momentum) "during the collision" you do need both v1 and v2 in the equation :smile:
Thanks :smile:, I am indeed a rabbit lol.
Ok so what are v1 and v2 here then? The velocity before the spring is compressed and the velocity once it is compressed? I guess I should have included this question in my original post because determining what v1 and v2 are is my real issue.
no, v1 and v2 are the speeds of the two blocks at any time during the collision …
they'll depend on x, the amount of compression at any particular time
ok, so we know that
(1/2)kx2 = potential energy in the spring when it is fully compressed.
If momentum is conserved, then when it is fully compressed
(1/2)M1Vo2 = (1/2)kx2
correct?
Hmm...we really haven't learned this in the class I'm in currently, but it seems like I would need to take the derivative of the velocity to be able to find the velocity for a given time. Is this along the right lines? If so, I need to do some more research on the problem because we have not yet learned how to do that...
thanks so much for your responses btw. I really did not expect anyone to even get back to me
hi nibbles19! :smile:
nibbles198 said:
ok, so we know that
why do you say "fully compressed"? :confused:
that is the correct formula for PE for any amount of compression
now just put the two KEs into the equation :smile:
Ahhh I think I've got it.
(1/2)kx2 = (1/2)M1V12 + (1/2)M2V22
Awesome thank you! (let me know if that's not right, but I'm pretty sure it is)
that's fine! :smile:
have a piece of lettuce! :wink:
FAQ: Conservation Laws and Collisions with a Spring
What is the concept of "Two masses and a Spring" in physics?
The concept of "Two masses and a Spring" is a simple mechanical system often used in introductory physics courses to study the behavior of masses connected by a spring. It involves two masses, usually denoted as m1 and m2, connected by a spring with a spring constant k. The system can be used to understand concepts such as simple harmonic motion, energy conservation, and oscillations.
How is the spring constant of a system with two masses and a spring calculated?
The spring constant, denoted as k, can be calculated by dividing the force applied to the spring by the displacement of the spring from its equilibrium position. Mathematically, it can be expressed as k = F/x, where F is the force applied and x is the displacement of the spring.
What is the equation for the total energy of a system with two masses and a spring?
The total energy of the system can be calculated by adding the kinetic energy and potential energy of the masses. Mathematically, it can be expressed as E = 1/2kx^2 + 1/2mv^2, where k is the spring constant, x is the displacement of the spring, m is the mass of the object, and v is the velocity of the object.
How does the displacement of the masses affect the period of the system?
The period of the system, the time it takes for one complete oscillation, is directly proportional to the square root of the mass and inversely proportional to the spring constant. This means that increasing the mass or decreasing the spring constant will result in a longer period, and vice versa.
What is the difference between simple harmonic motion and damped harmonic motion in a two masses and a spring system?
In simple harmonic motion, the system follows a sinusoidal pattern with no external forces acting on it. On the other hand, in damped harmonic motion, the system experiences external forces, such as friction, which cause the amplitude of the oscillations to decrease over time. This results in a gradual decrease in the total energy of the system.
