Conservation Laws and Velocity Reversal in 1D Collisions
In summary, the study of conservation laws in one-dimensional collisions focuses on the principles of conservation of momentum and energy, which govern the behavior of colliding objects. It examines scenarios such as elastic and inelastic collisions, where the total momentum before and after the collision remains constant. The concept of velocity reversal is analyzed, particularly in perfectly elastic collisions, where colliding objects exchange velocity while conserving kinetic energy. The findings highlight the significance of these laws in understanding motion and interactions in one-dimensional systems.
skoczek77
New user has been reminded to always show their work on schoolwork problems.
A body of mass m moving with speed v hits a resting body of mass M. After an ideally elastic collision, the masses move in opposite directions with equal velocities. Give the ratio of the masses of bodies m/M (as a number). We neglect friction.
principle of conservation of momentum and kinetic energy
i dont know how
What is the momentum and energy before the collision? What is the momentum and enetgy after the collision?
p=mv1 before and
p=-mv2 +Mv2 after
skoczek77 said:
p=mv1 before and
p=-mv2 +Mv2 after
That gives you an equation. Can you find another equation knowing that the collision is elastic?
with kinetic energy but idk how
skoczek77 said:
p=mv1 before and
p=-mv2 +Mv2 after
Right. So what's the kinetic energy of a moving body? And hence, what are the equivalent conservation equations for energy?
I've already done it, tell me if it's good:
0,5·m·v1²=0,5·(M+m)·v2²
m·v1²=(M+m)·v2²
v2=(m·v1)/(M-m)
m·v1²=(M+m)·(m·v1)²/(M-m)²
m·v1²=(M+m)·m²·v1²/(M-m)²
1=(M+m)·m/(M-m)²
(M-m)²=m·M+m²
M²-2·M·m+m²=m·M+m²
M²-2·M·m=m·M
M-2·m=m
M=3·m
so m/M=1/3
Yes, that's correct. I guess you never know when a sudden burst of algebraic creativity will strike!
Likes jbriggs444
yes, you are right, 2 hours ago I thought there was not enough data to solve it;
thank you very much for help
have a nice day ;)
For future reference, in a fully elastic 1D collision, a very simple relationship can be deduced from the conservation laws: the velocity difference is reversed.
That is, if the initial velocities are ##v_1, v_2## and the final velocities ##v'_1, v'_2## then ##v_1- v_2=v'_2- v'_1##.
In the present case, you have ##v_2=0, v'_2=-v'_1##, so ##v'_1=-\frac 12v_1##.
Combining that with momentum conservation gives the answer without involving quadratics.
For the imperfectly elastic version, see https://en.wikipedia.org/wiki/Coefficient_of_restitution
Btw, the question statement is wrong. Moving "in opposite directions with equal velocities" is not possible; equal speeds, yes.
Likes MatinSAR
FAQ: Conservation Laws and Velocity Reversal in 1D Collisions
What are conservation laws in the context of 1D collisions?
Conservation laws in the context of 1D collisions refer to the principles that certain physical quantities remain constant before and after a collision. The most relevant conservation laws are the conservation of momentum and the conservation of kinetic energy. In an isolated system, the total momentum and, in the case of elastic collisions, the total kinetic energy of the colliding objects remain unchanged.
What is velocity reversal in 1D collisions?
Velocity reversal in 1D collisions occurs when two objects collide elastically, and their velocities after the collision are such that they are reversed relative to each other. This typically happens when two objects of equal mass collide head-on in an elastic collision, resulting in each object moving with the velocity that the other had before the collision, but in the opposite direction.
How do you derive the final velocities of two colliding objects in 1D?
To derive the final velocities of two colliding objects in a 1D collision, you use the conservation of momentum and, for elastic collisions, the conservation of kinetic energy. Let the masses of the two objects be \( m_1 \) and \( m_2 \), and their initial velocities be \( v_1 \) and \( v_2 \). The final velocities \( v_1' \) and \( v_2' \) can be found using the following equations:For momentum: \( m_1 v_1 + m_2 v_2 = m_1 v_1' + m_2 v_2' \)For kinetic energy (elastic collisions): \( \frac{1}{2} m_1 v_1^2 + \frac{1}{2} m_2 v_2^2 = \frac{1}{2} m_1 v_1'^2 + \frac{1}{2} m_2 v_2'^2 \)Solving these equations simultaneously gives the final velocities.
What is the significance of elastic and inelastic collisions in 1D?
The significance of elastic and inelastic collisions in 1D lies in the different conservation laws that apply. In elastic collisions, both momentum and kinetic energy are conserved, which means that the total kinetic energy of the system remains the same before and after the collision. In inelastic collisions, only momentum is conserved, while some of the kinetic energy is converted into other forms of energy, such as heat or sound. This distinction is crucial for predicting the outcomes of different types of collisions.
Can you provide an example of a 1D collision involving velocity reversal?
Consider two objects, both of mass \( m \), moving towards each other with equal but opposite velocities. Let object 1
