MPat
- 15
- 1
Consider a uniform rod of mass 12kg and length 1.0m. At it's end the rod is attached to a fixed, friction free pivot. Initially the rod is balanced vertically above the pivot and begins to fall (from rest) as shown in the diagram. Determine,
a) the angular acceleration of the rod as it passes through the horizontal at B. (rod is horizontal with left end at pivot point)
b) the angular speed of the rod as it passes through the vertical at C. (rod is vertical with upper end at pivot point)
For the diagram picture a clock with hand pointing to 12 (for position A, initial position), 3 for position B, 6 for position C.
Given:
m=12kg
L= 1.0m
τ = Iα
PE = mgh
KE (rotational) = 1/2Iω^2
Irod = 1/3ml^2
a) α=?
τ = Iα
τ = rF, F = mg, τ = rmg, r=L/2 since center of mass will be at centre of rod
τ=L/2*mg
Iα=1/3ml^2α
L/2*mg =1/3ml^2α
Solve for α
m cancels out
3L/2L^2 = α
L cancels out
3/2L=α
3/2(1)= α = 1.5 rad/s^2
b) ω=?
mgh=KE
mgL/2=1/2(1/3ML^2)ω^2
mass cancels out
6gL/2L^2 = ω^2
3g/2L = ω^2
ω= sqrt (3*9.8/2*1)
ω = 5.42 rad/s
I'm just not sure if I got the answer correct. Is someone able to check? Was a little unsure of what numbers I was using as radius and center of mass.
Thanks
Miral
