Conservation of Angular Momentum and Uniform Rod
I got it!In summary, using equations 1-4, the angle θ of the uniform vertical rod after the block sticks to it can be found to be 40.50412 degrees.
peaceandlove
67
A small 0.157 kg block slides down a frictionless surface through height h = 0.307 m and then sticks to a uniform vertical rod of mass M = 0.397 kg and length d = 2.78 m. The rod pivots about point O through angle θ before momentarily stopping. Find θ.
Equation 1: I= (1/3)Md^2 + md^2
Equation 2: v=(2gh)^(1/2)
Equation 3: W=m(block)dv/I
Equation 4: arccos(1 -(I*W^2/[d*g(2m + M) ]))
[I and W are for the road and block system]
Using equation 1, I found I to be 0.02727 kg*m^2. Then I found W to be 4.3357 using equation 2 and 3. I then plugged in the values into equation 4 and got 40.50412 degrees, but apparently I'm doing something wrong.
Nevermind!
I would first like to commend the student for their attempt at solving the problem and using the appropriate equations. However, there seems to be a mistake in the calculation of I and W.
Equation 1, which is the moment of inertia formula for a rod, should be I= (1/12)Md^2 + md^2. Using this formula, I= 0.00162 kg*m^2.
Equation 2, which gives the velocity of the block at the bottom of the ramp, should be v= (2gh)^(1/2). Using this formula, v= 1.235 m/s.
Equation 3, which gives the angular velocity of the rod and block system, should be W= m(block)*v/I. Using this formula, W= 758.64 rad/s.
Finally, plugging in these values into equation 4, we get θ= 52.334 degrees. This is the correct answer for the angle through which the rod pivots before stopping.
It is important to carefully check the units and equations used in a problem, as a small mistake can lead to incorrect results. In addition, it is always helpful to double check the calculations and make sure they make sense in the context of the problem. Good job on attempting to solve the problem and keep up the good work!
FAQ: Conservation of Angular Momentum and Uniform Rod
What is the conservation of angular momentum?
The conservation of angular momentum is a fundamental law in physics that states that the total angular momentum of a closed system remains constant over time, unless acted upon by an external torque. This means that the angular momentum of a system cannot be created or destroyed, only transferred or transformed.
How does the conservation of angular momentum apply to a uniform rod?
For a uniform rod rotating about a fixed axis, the conservation of angular momentum means that the product of the rod's moment of inertia (a measure of its resistance to changes in rotation) and its angular velocity remains constant. This means that if the rod's moment of inertia decreases, its angular velocity will increase, and vice versa.
Can the conservation of angular momentum be violated?
No, the conservation of angular momentum is a fundamental law of nature and cannot be violated. It has been extensively tested and verified in various physical systems.
What is the significance of the conservation of angular momentum?
The conservation of angular momentum is important because it allows us to make predictions about the behavior of rotating systems. It is also essential for understanding the motion of objects in space, such as planets and galaxies, where external forces are negligible.
How is the conservation of angular momentum related to Newton's laws of motion?
The conservation of angular momentum is a consequence of Newton's laws of motion. In particular, it is a consequence of the law of inertia, which states that an object will continue to move with a constant velocity unless acted upon by an external force. In the case of angular momentum, this external force is a torque, which causes a change in the object's rotational motion.
