I Conservation of angular momentum during collisions
In collisions, angular momentum can be conserved even when linear momentum is not, provided the net external torque is zero. When analyzing a scenario with a hinged rod and a bullet, if the external forces are non-impulsive, their effect on angular momentum can be neglected during the brief collision interval. This holds true even if the forces create a torque, as long as they do not significantly influence the system's motion during the collision. The discussion emphasizes that both linear and angular momentum can disregard non-impulsive forces in such cases. Therefore, it is valid to conclude that angular momentum conservation applies similarly to linear momentum conservation in these contexts.
anon90
Hello everyone, I have a doubt regarding the conservation of angular momentum.
When dealing with collisions between two objects, if the net external force is zero we know that the linear momentum is conserved; even when the system is not isolated, for instance because of gravity acting on the said bodies, if the external forces are not impulsive (such as gravity force) we can neglect them, as their impulse over the small interval of the collision is small. So, while the linear momentum is theoretically not conserved, for all purposes it is.
Now, if we consider a rigid rod AB, hinged at point A, initially at rest in the vertical position, that can rotate around a horizontal axis passing on A, and we shoot a small bullet at the other extreme B, with a velocity perpendicular to the rod AB, the linear momentum is not conserved, as there will be an impulsive force on A keeping the rod fixed at that point.
That being said, if we choose A as the pivot the net external torque wrt that point is zero, and angular momentum is conserved.
Although this was a special case, since the torque due to the weight of both the bullet and the rod was zero because the rod starts in a vertical position, and the weights have the same direction... what if that is not the case?
My question is the following: if we have a system, and during a similar collision the next external torque is not zero, if the forces causing said torques are not impulsive, can we ignore them, and consider only the external torque due to the impulsive ones?
For instance if we have the rod on a horizontal plane and we shoot the bullet with a velocity perpendicular to it, but this time the weight of said bullet has a non zero torque wrt the hinge; the torque due to the weight of the rod is balanced with the torque due to the normal, if we assume the rod to be laying on a table.
My answer would be that yes, we can neglect them, since the angular impulse deriving from non impulsive forces will be close to zero when considering a small interval. So, again, we can say that the angular momentum will be approximately conserved wrt that specific pivot during the collisions if we choose to ignore, for instance, the torque due to gravity.
My doubt arises because in the books I've read so far (not English ones, so the titles won't matter) they always specify that you can ignore non impulsive forces for the linear momentum's conservation, but when talking about the angular momentum's, they never say so.
I've also noticed some videos online that treats such cases always ignore the torque due to non impulsive forces, without specifying why they do so.
Thanks in advance.
You have completely lost me with the description of this scenario.
I think that we have a rod which is connected to a horizontal hinge on one end. It is lying on a table so that it does not swing down to the vertical.
We fire a bullet vertically at the rod from from above. And for some reason we consider that the supporting force from the table does not become impulsive?!
The support force from the table most certainly will become impulsive in such a case. It is a constraint force. It will take on whatever value (including near-infinite impulsive values) is required to maintain the constraint.
I'm sorry that the description was that confusing, I've looked for some pictures online that may describe my situation and I've found the attached one.
Basically, instead of having a hanging rod, said rod is laying on a horizontal plane, and then we hit one extreme with a flying bullet.
During the collision the hinge will exert an impulsive force for sure, since that's why the rod is not moving away, but its torque wrt the hinge will be zero. The torque due to the weight and the normal force will balance each other, and either way they're not aligned with the axis of rotation.
My doubt was regarding to the torque due to the weight of the flying bullet, just before the collision: granted, it is once again not aligned with the axis of rotation, and since the rod cannot swing down to the vertical, so now that I think about it again I'm not even sure why I am considering it at all.
This bad example aside though, my question was whether one can, in general, neglect the torque of non impulsive forces during a collision in order to conserve the angular momentum, the same way we neglect non impulsive forces for linear momentum.
Yes, we can neglect non-impulsive forces for the duration of a brief collision, regardless of whether we are considering their effect on linear momentum or on angular momentum.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
