Conservation of angular momentum (electromagnetism)
In summary: I'm sorry for the confusion.In summary, the angular momentum of the system is initially due to the spinning cylinder and the magnetic and electric fields it produces. As the cylinder rotates, the magnetic field it produces decreases. Using conservation of angular momentum, we can find the angular velocity of the cylinder as it approaches infinity. In a realistic setup, the second term in the denominator of the equation for the angular velocity can be neglected, simplifying the calculation.
Screwdriver
129
An infinite wire of linear charge density [itex]\lambda[/itex] lies on the [itex]z[/itex] axis. An insulating cylindrical shell of radius [itex]R[/itex] is concentric with the wire and can rotate freely about the [itex]z[/itex] axis. The charge per unit area on the cylinder is [itex]\sigma = -\lambda/2\pi R[/itex] while the mass per unit area is [itex]\rho[/itex]. A magnetic field [itex]\mathbf{B} = B\hat{z}[/itex] fills the region of the cylinder.
At [itex]t=0[/itex] the cylinder is at rest and the magnetic field is reduced such that [itex]\mathbf{B}(t) = Be^{-t/\tau}\hat{z}[/itex].
Use conservation of angular momentum to find the angular velocity [itex]\omega[/itex] of the shell for [itex]t\to\infty[/itex].
Maxwell.
Inside the region of the shell, the magnetic field is initially just [itex]\mathbf{B} = B\hat{z}[/itex]. The electric field from a wire is [itex]\mathbf{E} = \lambda \hat{s}/2\pi \epsilon_{0} s[/itex]. Therefore, the momentum density is [itex]\mathbf{p} = \epsilon_{0}\mathbf{E}\times\mathbf{B} = \lambda B \hat{\phi}/2\pi s[/itex]. The angular momentum density is [itex]\mathbf{l} = \mathbf{s}\times \mathbf{p} = \lambda \hat{z}B/2\pi[/itex]. The total angular momentum per length is therefore [itex]\mathbf{L} = \int \mathbf{l} \,\text{d}V = \frac{1}{2}\lambda B R^2 \hat{z}[/itex].
Now, at [itex]t \to \infty[/itex], the ambient magnetic field goes to zero, so the angular momentum remaining is the angular momentum due to the spinning cylinder plus the angular momentum due to the magnetic field it's making and the electric field from the wire. When the cylinder is rotating, it's basically a solenoid, so the standard Amperian loop of hright [itex]h[/itex] gives [itex]B_{z}h = \mu_{0} I = \mu_{0} \frac{\text{d}Q}{\text{d} t} = \mu_{0} \frac{\text{d}Q}{\text{d} A}\frac{\text{d}A}{\text{d} t} = \mu_{0} \sigma \frac{\text{d}A}{\text{d} t} [/itex]. But then, [itex]\text{d} A = h \text{d} s = hR\text{d}\theta = hR\omega \text{d} t\implies \frac{\text{d}A}{\text{d} t} = h R \omega[/itex] so [itex]\mathbf{B} = \mu_{0}\sigma R \omega \hat{z} = -\frac{\mu_{0}}{2\pi}\lambda \omega \hat{z} [/itex]. This is just [itex]\mathbf{B} = B' \hat{z}[/itex] for [itex]B' = -\frac{\mu_{0}}{2\pi}\lambda \omega[/itex], so the result for the angular momentum of this field with the electric field still holds, and [itex]\mathbf{L}_{\text{field}} =\frac{1}{2}\lambda B' R^2 \hat{z} [/itex]. Finally, via conservation of momentum, [itex]\mathbf{L}_{0} = \mathbf{L}_{\text{field}} + \mathbf{L}_{\text{spin}}\implies \frac{1}{2}\lambda B R^2 = \frac{1}{2}\lambda B' R^2 + I \omega[/itex]. Also, the moment of inertia per length is [itex]I = mR^2 = \rho \frac{A}{h} R^2 = 2\pi \rho R^4[/itex], so we have [itex]\omega = 2\pi B\lambda/(8\pi^2 \rho - \mu_{0}\lambda^2)[/itex].
The issue is that I get I much simpler result via Faraday's Law, and since it was a lot simpler I assumed that this is somehow wrong.
You used I for two different things now.
The formula for I (as moment of inertia) does not look right. A/h is the surface area, not the interior - it is 2 pi R, not something with R^2. And then your result is I/h where h is a length in z-direction, as you express everything in "per length in z-direction".
That is a very interesting type of problem.
Likes 1 person
This is what I got also, using the conservation of angular momentum. [EDIT: Actually, I see now that I got a factor of R that you don't have: [itex]\omega = 2\pi B\lambda/[R(8\pi^2 \rho - \mu_{0}\lambda^2)] [/itex]. I think the missing factor of R in your expression is due to the mistake that mfb has pointed to.
[EDIT 2: After checking it over for the sixth time, I am no longer getting the factor of R in the denominator. So, I again agree with your answer. The dimensions seem to check, too. Sorry for the confusion and I hope I have it right now.] (Nope, See correction in post below)
In using Faraday's law, did you take into account the changing B field due to the increasing speed of rotation of the charged cylinder?
In any realistic setup, you would have ##\rho >> \mu_o \lambda## and ##\omega## will be very small [see correction in post below]. So you could safely neglect the magnetic field of the spinning cylinder in both approaches.
OK, feel free to shoot me.:redface: But now I'm getting
[itex]\omega = 2\pi B\lambda/(8\pi^2 \rho R - \mu_{0}\lambda^2) [/itex]. So, there's a factor of R in just the first term of the denominator and I believe the dimensions of the two terms in the denominator are now consistent. This is what you will get if you take into account mfb's remarks.
The correct comparison is that ##\rho R>> \mu_{0}\lambda^2## in any realistic setup. Then you can neglect the second term in the denominator which is equivalent to not worrying about the magnetic field produced by the rotating cylinder.
Likes 1 person
Ah yes, thank you! The dimensions were incorrect.
Applying the correction, we find the same result. Also, no, I didn't account for the changing magnetic field as the cylinder speeds up; doing this with Faraday yields the same answer, so it's probably right. Thanks again to both of you :smile:
Related to Conservation of angular momentum (electromagnetism)
1. What is conservation of angular momentum in electromagnetism?
In electromagnetism, conservation of angular momentum refers to the principle that the total angular momentum of a system remains constant unless acted upon by an external torque. This means that the combined angular momentum of all particles or objects in a system will remain the same, even if they individually change their rotational motion.
2. How is angular momentum conserved in electromagnetic interactions?
Angular momentum is conserved in electromagnetic interactions through the exchange of angular momentum between particles. When an object or particle experiences a torque due to an electromagnetic force, it will change its rotational motion and transfer some of its angular momentum to the other object or particle involved. This transfer of angular momentum ensures that the total angular momentum of the system remains constant.
3. What is the role of symmetry in conservation of angular momentum?
Symmetry plays a crucial role in conservation of angular momentum in electromagnetism. This is because the laws of electromagnetism, specifically Maxwell's equations, are inherently symmetric. This means that the forces and torques experienced by particles in an electromagnetic interaction will be equal and opposite, ensuring that the total angular momentum of the system remains constant.
4. Can angular momentum be created or destroyed in an electromagnetic interaction?
No, angular momentum cannot be created or destroyed in an electromagnetic interaction. This is due to the conservation of angular momentum principle, which states that the total angular momentum of a system will remain constant unless acted upon by an external torque. In other words, the total amount of angular momentum in a system cannot change, it can only be transferred between objects or particles.
5. How is conservation of angular momentum related to rotational symmetry in electromagnetism?
In electromagnetism, rotational symmetry refers to the invariance of physical laws under rotations around a fixed point. This symmetry is closely related to the conservation of angular momentum, as it ensures that the laws of electromagnetism treat all directions and rotations equally. This symmetry, along with the conservation of angular momentum, allows for the prediction and understanding of various electromagnetic phenomena and interactions.
