Conservation of angular momentum in scattering processes
In summary, the conversation discusses the conservation of angular momentum in a system involving a scattered particle and a particle generating a gravitational potential. The Lagrangian and reduced mass are mentioned, and it is noted that the quantity L is conserved. The conservation of angular momentum is then questioned, specifically in cases where r and v are not orthogonal. It is concluded that while the conservation of angular momentum still applies in scattering and orbiting, the transfer of momentum to the massive object may be negligible and can be ignored.
gabu
Greetings.
So... let us consider a particle moving in the yz plane, coming from the infinite towards a region were a gravitational potential is appreciable. The Lagrangian of the system is
[itex]\mathcal{L} = \frac{1}{2}\mu (\dot{r}^2+r^2{\dot \phi}^2) + \frac{G\,m\,M}{r}[/itex]
where [itex]\mu [/itex] is the reduced mass and [itex]r[/itex] is the relative distance between the scattered particle and the particle generating the gravitational potential. From this Lagrangian we take that the quantity
[itex]L = m\,r\,v [/itex]
is conserved, right? Now, from the angular momentum vector we have,
[itex] \vec{L} = m\,(y\,\dot{z} - z\,\dot{y}) [/itex]
and [itex]|\vec{L}| = m\,r\,v\,\sin\theta [/itex] where [itex]\theta[/itex] is the angle between [itex]r[/itex] and [itex]v [/itex].
So... my problem is, the angular momentum is then only conserved when [itex]r[/itex] and [itex]v [/itex] are orthogonal? So, it doesn't really apply to scattering, only for orbiting particles?
Thank you very much.
Science news on Phys.org
Scattering and orbiting involve an External Force. Momentum is transferred to the 'other' object which provides the Force. Just because that object is massive, (net) momentum conservation still applies.
The Energy lost to the massive object may be near-zero and ignored.
Related to Conservation of angular momentum in scattering processes
1. What is conservation of angular momentum in scattering processes?
Conservation of angular momentum in scattering processes is a fundamental principle in physics that states that the total angular momentum of a system remains constant before and after a scattering event. This means that the initial angular momentum of the system must be equal to the final angular momentum, taking into account any external torques acting on the system.
2. Why is conservation of angular momentum important in scattering processes?
Conservation of angular momentum is important in scattering processes because it helps us understand the behavior of particles in these interactions. It allows us to predict the outcomes of scattering events and analyze the properties of the particles involved.
3. How does conservation of angular momentum affect the trajectory of particles in scattering processes?
Conservation of angular momentum affects the trajectory of particles in scattering processes by influencing the direction and speed of their motion. This is because the total angular momentum of the system must remain constant, so any changes in one particle's angular momentum must be offset by an equal and opposite change in another particle's angular momentum.
4. Can conservation of angular momentum be violated in scattering processes?
No, conservation of angular momentum is a law of physics and cannot be violated in scattering processes. If the initial and final angular momenta of a system do not match, it means that there are external torques acting on the system that were not accounted for.
5. How is conservation of angular momentum applied in real-world scenarios?
Conservation of angular momentum is applied in various real-world scenarios, such as in particle accelerators, where it is used to study the properties of subatomic particles. It is also important in understanding the motion of celestial bodies, such as planets and stars, and in analyzing the behavior of spinning objects, such as tops and gyroscopes.
9K
