Conservation of Angular Momentum of a bird
In summary: L = L1 = L2L1 = (m_b+m_r-r_b)*v(r_b) = L2 = I wv = w rhence... m_b v_b (0.74-.25) = 1/3 m_r (0.74)^2 w + m_b (0.25)^2 wYou'll get the same answer.In summary, the bird with a mass of 0.470 kg and an initial velocity of 2.50 m/s collides with a stationary vertical rod with a mass of 1.60 kg and length of 0.740 m. After the collision, the bird is stuck to the top of the rod at a distance of
RJLiberator
63
A bird m_b=0.470kg, is flying horizontally at v_b=2.50 m/s, not paying much attention, when it suddenly flies into a stationary vertical rod, hitting it d=25cm below the top. The rod is uniform, L=0.740m long, has a mass of m_r =1.60kg and is hinged at its base. This time the bird goes splat on the rod, and is stuck to it at the point of impact. What is the angular velocity w_f of the bird+rod just after the collision?
What we have:
Mass of bird: 0.470 kg
Mass of rod = 1.60 kg
Initial Velocity of bird: 2.50 m/s
Length of rod = 0.740m
Distance of impact from top of rod = 0.25m
I_rod = 1/3M*d^2
Conservation of Angular Momentum L_0=L_1
L = mvrsin(theta)
L= Iw
v=w*r
First I calculated the Angular momentum of the bird prior to collision
L=mrv
L=0.470kg*(0.740m-0.25m)*2.50m/s
Sin here is 90 degrees and thus is simply 1.
L=0.57575
*NOTE: Did I use the right measurement for r?
Next, I found the post-collision angular momentum to be:
L_f=(m_b+m_r)*v_1*r + I_rod*w_f
L_f=(m_b+m_r)*d^2*w_f+(1/3)*m_r*d^2*w_f
Simple algebraic manipulation gets us:
w_f=0.57575/((0.470+1.6)(0.490^2)+(1/3)(1.60)(0.490^2))
for an answer of 0.921 rads/sec
My questions/concerns:
1) Is this the right method to approach this problem? Do I have any need to use conservation of mechanical energy to help solve this problem? All I am looking for is w_f.
2) Did I use the correct value for d throughout this problem? Namely (0.740-0.25).
3) Is it okay to be using the moment of inertia about the end of the rod for this problem? (1/3*M*d^2)
Thank you.
What we have:
I_rod = 1/3M*d^2
L = mvrsin(theta)
L= Iw
v=w*r
L=mrv
L=0.57575
Yes, r=L-0.25.
The term m_r must not be there. And what is d?
The moment of inertia of the rod+bird system is I (bird) + I(rod). The bird can be considered as a point mass, I_b=m_b r2, and you know the moment of inertia of the rod. The whole system rotates with angular speed w_f
Thank you.
1) Yes, the method is correct, but you have some errors.
2)The mechanical energy is not conserved as the bird and rod move together after the collision.
Well, what are d and r? You seem to mix them.
3) yes, you can use the moments of inertia about the end of the rod, but you need to use different lengths for bird and rod.
Likes RJLiberator
Interesting.
Wouldn't m_r be needed here as it is now part of the total system? I'm not quire sure why it would only be m_b needed here?
I am using d=r is this wrong? I would think d = (0.740-0.25)?
Hm, I see. So I would have to change my equation to:
L_1 = (m_b+m_r)*d^2*w_f+(I_rod+I_bird)w_f where I_rod = (1/3)(m_r)(d^2) and I_bird = m_b*d^2
This makes sense. =)
RJLiberator said:
.Wouldn't m_r be needed here as it is now part of the total system? I'm not quire sure why it would only be m_b needed here?
The angular momentums add. That of the bird is m_b v_b(final) r_b where r_b = d.
That of the rod is I w, r = 0.74 m, I =1/3 M_r r^2
No, it is wrong.
Likes RJLiberator
Okay. So that DOES make sense. The angular momentum of the bird and rod are adding. So the mass of rod is unneeded in the part regarding the bird, and the birds r = 0.49 while the rods d = 0.740.
So now the corrected equation is
L_1 = m_b*v*r+(I_rod)w_f
which simplifies to
L_1 = m_b*r^2*w_f+(1/3)m_r*d^2*w_f
where r=0.49 and d=0.740
Or, do I need it to be (I_rod+I_bird) ?
If so, why do we need both for this, but not both masses (bird+rod) previously?
Thank you again.
which simplifies to
Thank you again.
It will work now.
You can factor out w_f, but not the masses: they are multiplied by different length-squares.
Likes RJLiberator
So I do NOT need to use I_b+I_r ?
If this is the case, then I get:
w_f= Angular momentum initial/((m_b*r^2)+(I_r))
w_f=0.57575/((0.47+0.49^2)+((1/3)(1.6)(0.74^2)))
w_f=1.422 rads/sec
w_f=1.422 rads/sec
It is correct! :cool:
But you have used I=I_b+I_r!I think that + is just typo.
Likes RJLiberator
Awesome. I appreciate your help, but have one last clarifying question:
Earlier you stated:
But here in the end, I did not use this. I only used I_rod.
What happened here?
Earlier you stated:But here in the end, I did not use this. I only used I_rod.
What happened here?
w_f=0.57575/((0.47*0.49^2)+((1/3)(1.6)(0.74^2)))
I write it out into a readable form.
## \omega_f = \frac{0.57575}{0.47\cdot .49^2 + \frac{1}{3}\cdot 1.6 \cdot 0.74^2}##
The denominator is the sum of the moments of inertia: that of the bird and that of the rod.
Likes RJLiberator
Oi! That makes sense. I can see it clearly now.
I appreciate your time and help. You have indeed helped me on my path of learning!
Thank you.
You are welcome. :oldsmile:
Likes RJLiberator
Related to Conservation of Angular Momentum of a bird
1. What is conservation of angular momentum?
The conservation of angular momentum is a fundamental law of physics that states that the total angular momentum of a system remains constant unless acted upon by an external torque. In simpler terms, it means that a rotating object will continue to rotate at a constant rate unless a force is applied to it.
2. How does conservation of angular momentum apply to birds?
Birds are able to fly and perform impressive aerial maneuvers due to their ability to conserve angular momentum. When a bird flaps its wings, it creates a torque that is balanced by the rotation of its body, allowing it to maintain its flight path and stability.
3. How does a bird's wing shape affect its conservation of angular momentum?
A bird's wing shape plays a crucial role in its conservation of angular momentum. A longer and narrower wing allows for more efficient rotation, while a shorter and broader wing provides more stability. This is why different bird species have different wing shapes suited for their specific flight patterns.
4. Are there any factors that can disrupt a bird's conservation of angular momentum?
Yes, there are several factors that can disrupt a bird's conservation of angular momentum. Strong winds, turbulence, and sudden changes in direction can all cause external torques that can affect a bird's flight and ability to conserve angular momentum.
5. How does conservation of angular momentum impact a bird's ability to land?
When a bird is about to land, it adjusts its wings and body to create a counter-torque that slows down its rotation and allows for a smooth landing. This is a perfect example of how a bird's conservation of angular momentum is crucial for its flight and movement.
9K
