Conservation of Angular Momentum Problem
In summary, the problem involves a block of mass 3.0 kg sliding down a frictionless surface from a height of 0.66 m and colliding with a uniform vertical rod of mass 4.4 kg and length 2.8 m. The block then sticks to the rod and together they pivot about point O before coming to rest. The solution involves using conservation of energy to find the speed of the block at the bottom of the ramp, conservation of angular momentum to find the angular velocity, and conservation of potential energy to find the height that the center of mass of the system will rise. Finally, the angle that the rod and block pivot about can be found by using the distance between the pivot and the center
Moxin
24
A block of mass 3.0 kg slides from rest down a frictionless surface from a height 0.66 m. The block collides with a uniform vertical rod of mass 4.4 kg and length 2.8 m and sticks to it. Find the angle theta that the rod and block pivot about O before momentarily coming to rest.
I've uploaded the associated picture here ~> http://www.villagephotos.com/viewpubimage.asp?id_=5655439&selected=550922
lemme just say, I have NO CLUE how to even approach his problem, but following an example in my horrible, HORRIBLE, textbook, I did this:
Kf = Kinetic Energy after the inelastic collision
d = length of rod
Kf = (L^2)/2I
L = mvd
So:
Kf = ((mvd)^2)/2(md^2+(1/3)md^2) = 143943.8155
..lol..I decided to give up after that since I have No clue at all what to do with that absurdly large number.. At first I thought about dividing it by the weight of the system.. but I don't think I'd get very far in the right direction by doing that..any suggestions??
THis is a three part problem:
First, you determine the speed of the block at the bottom of the ramp. Use the conservation of energy (U at the top = K at the bottom). Find " v "
Then it is a conservation of angular momentum problem, where you have an inelastic collision. The initial " L " is that of the moving block at essentially a radial displacement of " d ". This is the amount of angular momentum that must be consterved. After the collision, you have a 2 piece object. The "moment of inertia" (I) of the block is mass x d^2 . Moment of inertia for the rod rotating about its end is (md^2)/2 .
THe third part is figuring out how high the center of mass of the system will rise. THis can be done using the conservation of energy again.
Um, I thought I did that
At least, that's what I think I did now that I've tried tackling similar problems and have a better understanding of the concepts..
Ok let me try this again
Using conservation of Energy:
v(block)= sqrt(2gh) = 3.598 m/s
So: L = mvd = 30.2232
I'm thinkin you meant I for rod is (1/3)md^2 (standard formula of "thin rod about perpendicular line through one end" given by book) .. So:
I' = md^2 + (1/3)Md^2 where m is the mass of the block and M is the mass of the rod
I' = 23.52 + 11.4986 = 35.0187
Rotational Kenetic Energy = (1/2)Iw^2 where w is angular velocity
so Rotational Kenetic Energy = (Iw^2)/2I = L^2/2I
So K = (30.2232^2)/2(35.0187) = 15993.7725
lol hmm.. diff answer, I must've messed up somewhere in the original calculation, but anyways, on to the next step..
(M+m)gh = K
h = K/((M+m)g) = 220.31 m ?? that seems still too high, but aiight, moving along
to find the angle from there I assume I'd have to use the equation d = dcos(theta) + h
so arccos((d-h)/d) = theta = error
I think you're overcomplicating.
In the initial and final states, there is no motion.
So why worry about velocities?
All you need is the conservation of potential energy.
Imagine the rod had zero mass. Then, clearly, the block would come to rest at the same height where it has started.
Now since the rod has actually finite mass, some energy will go into the lifting of the rod's center-of-mass. Since this is located at the center of the rod, it will go up exactly half as much as the block does.
This info is enough to find the answer from a simple equation.
Oops, wait...
What I said might be wrong. Since when things stick, there is some energy absorbed. So I better step thru your detailed analysis to see if I can find some errors...
OK.
OK. Better: L = mvd = 30.2232 m2kg/s
OK. Better: I' = 35.0187m2kg
OK.
The I in the middle term's denominator shouldn't be there. However, the final term is OK. Should read:
Rotational Kenetic Energy = (Iw^2)/2 = L^2/2I
Here's a bad mistake.
You used your calculator in a wrong way.
You probably typed (30.2232^2) / 2 * (35.0187) =
But you should have typed (30.2232^2) / 2 / (35.0187) =
(M+m)gh = K
Here's another mistake.
As I said, the center-of-mass of the rod only goes up half as much as the block. Should read:
(M/2 + m)gh = K
d = dcos(theta) + h
OK again.
OK once more.
Use the new values of K and h, and I guess you will be fine.
You could also find the position of the center of mass of the block-rod system. (See the c-o-m part of the text, usually with linear momentum). Find how high this point must rise (rotational K becomes U), call it "h". Then find the angle in the triangle where the hypotenuse is "d" and the adjacent side is "d-h."
edit: no no! Don't do that! The hypotenuse is the original c-o-m distance from the pivot (call it "s"), and the adjacent side is "s-h".
Thanks for the help Y'all! That problem was killin me
FAQ: Conservation of Angular Momentum Problem
What is the conservation of angular momentum problem?
The conservation of angular momentum problem is a principle in physics that states that in a closed system, the total angular momentum remains constant. This means that if no external torque acts on a system, the total angular momentum of that system will remain the same.
Why is the conservation of angular momentum important?
The conservation of angular momentum is important because it is a fundamental law of nature that helps us understand the behavior of objects in motion. It is also used in many areas of physics, such as astronomy, mechanics, and fluid dynamics.
How is angular momentum conserved in a closed system?
In a closed system, the total angular momentum can be conserved in two ways: by changing the moment of inertia (the distribution of mass in the system) or by changing the angular velocity (the speed of rotation). This is known as the law of conservation of angular momentum.
What is an example of the conservation of angular momentum in action?
A classic example of the conservation of angular momentum is seen in figure skating. When a skater pulls their arms closer to their body, their moment of inertia decreases, causing them to spin faster. This is because the total angular momentum must remain constant, so as the moment of inertia decreases, the angular velocity must increase.
Can the conservation of angular momentum be violated?
No, the conservation of angular momentum is a fundamental law of nature and cannot be violated in a closed system. However, in an open system where external torques can act on the system, the total angular momentum may change over time.
