Conservation of Angular Momentum sun problem
In summary, the problem involves a star with the same mass and radius as the Sun, rotating with a period of 25 days, collapsing to become a white dwarf with 53% of the Sun's mass and a rotation period of 131 seconds. The solution involves using conservation of angular momentum and approximating the star as a rotating, solid sphere with uniform density.
Godcanthelp
When a star like our Sun exhausts its fuel, thermonuclear reactions in its core cease, and it collapses to become a white dwarf. Often the star will blow off its outer layers and lose some mass before it collapses. Suppose a star with the Sun’s mass and radius (the radius of the Sun is 6.96×108m ) is rotating with period 25 days and then it collapses to a white dwarf with 53% of the Sun’s mass and a rotation period of 131 s.
Conservation of Angular Momentum:
Angular Momentuminitial = Angular Momentum final
Angular Momentum = Rotational Inertia (sphere) * Angular Velocity (ω)
Rotational Inertia (sphere) = 2/5MR2
ωsun = 2∏/(25*24*60*60) rad/sec
ωwd = 2∏/131 rad/sec
Isunsun = Iwdwd
(2/5)*Msun*Rsun2*2∏/(25*24*60*60) = (2/5)*Mwd*Rwd2*2∏/131
Msun*(6.96*108)2*1/(25*24*60*60) = 0.53*Msun*Rwd2*1/131
(6.96*108)2*1/(25*24*60*60) = 0.53*Rwd2*1/131
Rwd2 = 131*(6.96*108)2*1/(25*24*60*60) *1/0.53
Rwd = 7.44526*106m
Which is incorrect.
Hello Godcanthelp,
Welcome to Physics Forums!
Isunsun = Iwdwd
Rwd = 7.44526*106m
Which is incorrect.
You seem to have left out the the primary goal in the problem statement. Are you supposed to find the white dwarf's radius?
The approach you are using makes a few approximations, such as the original star having a uniform density. And crazy as it sounds, it's difficult to gauge a real star's rotation rate since it rotates at a different angular speed at its equator than it does at it's poles (I know, weird huh).
But let's just approximate it as a rotating, solid sphere with uniform density anyway.
Only 53% of the original star's mass ends up collapsing into a white dwarf. The rest gets blown off.
My guess is you should not start with the angular momentum of the entire star. Instead, only consider the inner 53% of that star. So first, find the radius of the inner 53% by mass of that star. Then apply conservation of angular momentum after that.
FAQ: Conservation of Angular Momentum sun problem
1. What is the conservation of angular momentum?
The conservation of angular momentum is a fundamental principle in physics that states that the total angular momentum of a system remains constant in the absence of external torques. This means that the rotation or spinning of an object will not change unless acted upon by an outside force.
2. How does the conservation of angular momentum apply to the sun?
The conservation of angular momentum applies to the sun in the same way it applies to any other rotating object. The sun is constantly rotating on its axis, and its angular momentum remains constant unless external forces, such as gravitational pulls from other celestial bodies, act upon it.
3. Can the conservation of angular momentum explain why the sun and planets orbit in the same direction?
Yes, the conservation of angular momentum can explain why the sun and planets orbit in the same direction. When the solar system was formed, a large cloud of gas and dust collapsed and began to rotate, due to the conservation of angular momentum. As the cloud collapsed, it flattened into a disk, with the sun at the center and the planets orbiting in the same direction as the initial rotation.
4. How does the conservation of angular momentum affect the shape of the sun?
The conservation of angular momentum does not directly affect the shape of the sun. However, the rotation of the sun does contribute to its oblate shape, where the equatorial diameter is larger than the polar diameter. This is due to the centrifugal force caused by the rotation, which balances out the gravitational force pulling towards the center.
5. Can the conservation of angular momentum explain the sun's magnetic field?
Yes, the conservation of angular momentum can explain the sun's magnetic field. As the sun rotates, it generates a magnetic field due to the movement of charged particles within it. This magnetic field is also affected by the conservation of angular momentum, as any changes in the rotation of the sun can impact the strength and direction of the magnetic field.
