Conservation of Angular Momentum with Changing mass
In summary, the angular velocity of the spinning fireworks display is 8.105 radians per second when the gunpowder is exhausted.
cozzbp
I am completely stuck on this problem, and was wondering if anyone could point me in the right direction.
In the spinning fireworks display shown in the figure the ignited gun powder is ejected from the jets at a speed of 24.3 m/s.
http://volta.byu.edu/ph121/homework/hw18f2.png
The jets are a distance of 0.462 m from the center of the fixture. If the total mass of gunpowder from all four jets is 250 g and the total mass of the jets themselves is 472 g, what will the angular velocity in radians per second of the fixture be when the gunpowder is exhausted? Neglect air resistance and assume that the mass of the arms of the fixture is inconsequential. Take the counter-clockwise direction (out of the page) as positive.
L = mvr
L = I[tex]\omega[/tex]
Here is what I have tried thus far.
I thought that I could simply calculate the Angular Momentum (L) by doing the following:
L = 4*((mfuel/4 + mrocket/4) * v * r)
4*(.1805 * 24.3 * .462) = 8.105
then I simply subtracted the mass of the fuel for one rocket, and solved for v
8.105=4*(.118*v*.462)
This apparently does not yield the correct answer.
Any help would be greatly appreciated!
first line L=mvr. v is the velocity of the gas, not the jet.
Also you need to consider the total angular momentum before and after.
Welcome to PF.
Consider that there is a conservation of angular momentum. Initially, it is 0, so that suggests that after burn it will be the same won't it?
So won't that mean that
m_p*v*r = I * ω
where I = m_r*r2
m_p would be the mass of the gunpowder ejected
m_r would be the mass of the rocket pods.
Simplifying then doesn't that give
ω = (m_p * v)/(m_r * r)
Thank you both very much. That is exactly what I needed! My only question would be how did you know what the moment of inertia would be for that system?
I=mr2 for every point mass on the system. r is the distance between the point mass and the axis of rotation.
In here you can just assume the outlets are point masses since the arms are light.
But in general you need to sum up all the point masses so
[tex]I=\sum m_{i}r_i^{2}[/tex]
Oh ok, that makes sense. Thanks again!
FAQ: Conservation of Angular Momentum with Changing mass
What is conservation of angular momentum with changing mass?
Conservation of angular momentum with changing mass is a fundamental principle in physics that states that the total angular momentum of a system remains constant, even when there are changes in the mass or distribution of mass within the system. This means that the rotational motion of a system will remain the same unless acted upon by an external torque.
How does conservation of angular momentum with changing mass apply to real-life situations?
This principle applies to many real-life situations, such as ice skaters spinning faster as they pull their arms in, or a figure skater performing a spin with their arms extended. It also explains why a spinning top will stay upright as long as it is rotating fast enough, and why planets and satellites maintain their orbits around a central body.
What is the equation for calculating angular momentum?
The equation for angular momentum is L = Iω, where L is the angular momentum, I is the moment of inertia, and ω is the angular velocity. This equation shows that angular momentum is directly proportional to the moment of inertia and the angular velocity.
How does changing mass affect angular momentum?
Changing the mass of a rotating object will affect its angular momentum. As the mass is increased, the moment of inertia also increases, resulting in a decrease in angular velocity to maintain the same value of angular momentum. Similarly, decreasing the mass will result in an increase in angular velocity.
What are some practical applications of conservation of angular momentum with changing mass?
Conservation of angular momentum with changing mass has many practical applications in engineering and technology. It is used in designing flywheels for energy storage, gyroscopes for navigation systems, and centrifuges for separating substances based on their density. It is also essential in understanding the motion of celestial bodies and the behavior of rotating systems such as turbines and motors.
