Conservation of Angular Momentum
In summary, the lab question discusses the concept of conservation of momentum and angular momentum in a system of two rotating disks. The force that generates the torque during the collision is friction between the two disks. However, this torque does not account for experimental discrepancies between the final and initial angular momentum, as the friction causes a loss of energy in the system. Therefore, the final system of two disks stuck together will have half of the original speed and energy.
benny1993
Suppose I have a system of two disks (identical in mass and size) one is fixed to a shaft at it's center point and rotating due to an external torque that's removed as soon as the rotational motion begins. The second disk is dropped from rest over the rotating disk and sticks together to the rotating disk. What would be the force that generates the torque that accelerates the disks during the collision?
If there are no external forces acting on the system (since the accelerating external force is removed as soon as motion begins), the net torque has to equal zero. I don't get what other force actually causes the torque the accelerates the already rotating disk (which would be decreasing) and the torque that accelerates the dropped disk?
Friction is the force as the two disks touch each other.
But I think the question you're really looking for is conservation of momentum for the two-disk system.
So is the torque that rotates the stationary disk is caused by the force of friction? The next questions asks to explain why this torque (that rotates both disks) can't account for experimental discrepancies between the final and initial angular momentum, given that we neglected friction in the experiment.
benny1993 said:
Summary: Lab Question on Angular Momentum Conservation.
If I picture it right, one disk accelerates and the other decelerates. After a brief time, they rotate at the same speed. If that's not it, can you describe it better?
That's exactly how the experiment goes. One disk is rotating while the other is dropped from rest. Immediately after, they both begin to rotate at the same speed.
The rough surface of the static disk receives a large number of small hammer blows from the rough surface of the spinning disk. I mean the small hammers are spinning around.
If the disk is dropped from high position, then the torque is very large and lasts a very short time. I mean the torque caused by the hammer blows.
If the disk are smooth and sticky instead of hard and rough, then the story must be changed somehow.Oh, it was already agreed that friction is the cause of the force. Maybe the above is redundant then. So, is the final thing (two disks stuck together) not spinning at half of the upper disk's original speed? And with the same angularar momentum? And at half of the energy?
you have the moving disc and the one dropped on it.. the friction will be a force that decelerates the bottom disc and accelerates the upper disc, so there is an exchange of momentum through the friction. besides the loses in friction , noise and heat, the net momentum will remain constant (minus that small value of the momentum of the shaft the bottom disc has) which will spin up the upper disk and slow down angularly , the bottom disc.
benny1993 said:
Next questions asks to explain why this torque (that rotates both disks) can't account for experimental discrepancies between the final and initial angular momentum, given that we neglected friction in the experiment.
The torque between the disks is internal and does not change the angular momentum of the two disk system. The external torques come from friction at the bearings and beteween disks and air.
Likes sophiecentaur
Woops! Rotational energy is given by Iω2/2 so, although the Momentum is conserved, the total final Energy will be Half the original. (Two times one quarter) The energy went away due to the friction, whatever the friction force happens to be. It will just take longer or less time to reach equal speeds, depending.
This paradoxical looking result is a common sort of result that you get with many other idealised systems. The best known example is what happens when you connect two Capacitors (one charged and one discharged) together. Again you lose half the energy,
excellent!
Related to Conservation of Angular Momentum
What is conservation of angular momentum?
Conservation of angular momentum is a physical law that states that the total angular momentum of a closed system remains constant over time. This means that the total amount of rotational motion in a system cannot be created or destroyed, only transferred between objects.
Why is conservation of angular momentum important?
Conservation of angular momentum is important because it helps us understand and predict the behavior of rotating objects. It is also a fundamental principle in physics and is used in many applications, such as spacecraft navigation and understanding the motion of planets.
How is angular momentum conserved?
Angular momentum is conserved through the principle of action and reaction. When two objects interact, the angular momentum of the system remains constant as long as there are no external torques acting on it. This means that if one object gains angular momentum, the other object must lose an equal amount.
What factors affect angular momentum?
The two main factors that affect angular momentum are the mass and velocity of an object. An object with a larger mass or a higher velocity will have a greater angular momentum. Additionally, the distance between the object and its axis of rotation also plays a role in determining angular momentum.
Can angular momentum be changed?
Angular momentum can be changed by external forces or torques acting on the system. However, the total angular momentum of a closed system will always remain constant. This means that while the angular momentum of individual objects may change, the total amount of angular momentum in the system will not.
14K
  • Mechanics
  • Mechanics
