In summary, the conversation discusses the relationship between electric potential energy production on a conductor and conservation of energy, using the photoelectric effect as an example. The main point of confusion is whether the material-specific work function (φ) should include the post-ejection electric potential energy of the conductor (Efin) or not. It is concluded that energy is conserved because φ does include Efin, but there are also situations where Efin may not be included and further exploration is needed to fully understand the effects on energy conservation.
G Cooke
33
I'm having trouble seeing how electric potential energy production on a conductor follows conservation of energy.
Let's use the photoelectric effect as an example. A photon with energy E = hν strikes a conductor, ejecting a photoelectron with a maximum kinetic energy of hν - φ. Assuming the maximum kinetic energy is achieved, this leaves only φ to be transferred from the photon into the conductor.
However, we know that electrical energy follows the equation E = QV = Q2/C, which implies that the electric potential energy produced on the conductor by the photoelectric effect is equal to Eprod = Efin - Einit = (Qinit + Qelec)2/C - Q2init/C, which clearly increases with initial charge. Since φ is a constant, this implies that it is possible for Eprod to be greater than φ, which appears to violate conservation of energy since φ was the total amount of energy that entered the conductor.
Clearly I'm missing something. Any help would be much appreciated.
If the target for the photoeffect has a positive charge, φ increases. Typically the electrons have some path to flow back to it or the total number of electrons knocked out is negligible so this is rarely an issue.
That is true; however, even if we assume zero initial charge, there appears to be a problem.
With Qinit = 0, we have φ at its base value (i.e., no stopping potential) and Eprod = Efin - Einit = Q2elec/C - 0. So φ is a constant, and Eprod depends on C, which is arbitrary. Thus, it is possible that Eprod is greater than φ, again appearing to violate conservation of energy.
You can't make C small enough to make Eprod relevant compared to φ. In fact, φ will simply include this tiny amount of energy already.
I'm not so sure about that. To make Eprod > φ, algebra says all we need is C < Q2elec/φ, which is about 1e-38F...pretty small, but impossible?
Could you elaborate on this?
It is impossible. Even a spherical capacitor with "infinite" separation from the rest of the universe will have a capacitance of ##C=4 \pi \epsilon_0 r##. Solving for r, we get 10-28 meters. That is 13 orders of magnitude smaller than a proton. You can't make a metallic sphere of that size.
φ is the energy needed to remove an electron from the material. This includes the electrostatic attraction from the metal that now has a single positive charge - in principle, in practice it is negligible.
I see. But actually, my math is 19 orders of magnitude off because I forgot that φ will be in units of Joules rather than eV here. So I guess this makes the sphere 6 orders of magnitude larger than a proton. Still impossible, I presume?
Interesting. I was actually just about to type that this would all be cleared up if (1) the maximum kinetic energy of the photoelectron is hν - φ and (2) φ is defined as the material-specific work function W plus the FUTURE stopping potential Efin, i.e., the electric potential that will be on the conductor after the photoelectron is ejected. That would make intuitive sense anyway since it would seem to be the post-ejection potential that actually pulls on the photoelectron, not the pre-ejection potential.
So it looks like my whole problem was that I originally had φ defined as just the material-specific work function W rather than W + Efin.
For what it's worth, if it were the pre-ejection potential, then conservation of energy could be proven violated assuming divergence of the sequence Eprod, n = (2n+1)Q2elec/(W + (W/C)Eprod, n-1), Eprod, 0 = Q2elec/W.
0.7 nm (assuming φ=2 eV) Still impossible to have a metal with the usual electron bands with that size. Instead of the photoeffect you can get ionization of individual atoms. There the attraction is important - the whole ionization energy comes from this attraction.
Likes G Cooke
So I realize now that energy is conserved because φ includes the post-ejection electric potential energy Efin of the the conductor, which it must because the newly ejected photoelectron is caught inside the electric field from the now positively charged conductor and must overcome its force in order to escape.
But what if the geometry of the conductor is such that the electric field is zero in the region where the photoelectron ejects from it? For example, if the photon strikes the inner surface of a spherical shell, the charge left by the ejected photoelectron will distribute evenly around the shell, creating a zero net electric field inside the shell (Gauss's law) so that the photoelectron feels no attractive force. That implies φ here does not include Efin. Yet, it would seem that the conductor still acquires electric potential energy Efin due to its charge (assume the photoelectron gets decelerated by collisions with air molecules inside the shell so that it doesn't cancel out the conductor's charge). It appears that we can now have Efin > φ and, by extension, Eprod > φ, yet again appearing to violate conservation of energy.
That process takes some time.
φ is a description of a macroscopic quantity. It doesn't help to search for effects of individual charges on it. That's like asking what the temperature of a macroscopic object is if one particular atom in it has a slightly higher energy at this point in time.
As someone who studies photoemission and does experimental work in it, I find this whole thread to be extremely confusing.
First of all, the work function of a metal that we know and love includes a number of physical effects, INCLUDING the image-charge potential of the emitted photoelectrons when it is very close to the metal surface. This is part of the potential that it has to overcome to escape the bulk material. It is why electrons emitted with little to no KE will never escape, because the image potential will suck it back in. So to ask about a region where there will be no "electric field" on the surface upon emission is puzzling.
Secondly, the photoelectric effect is done on metals that are grounded. It means that (i) there is no charging effects and (ii) the band structure is not modified due to photoelectron emission. If it isn't grounded and charging effects occur, then in the simplest cases, the potential barrier will continue to increase with each electron emission until it is high enough that photons with a specific energy will no longer cause any photoelectron emission.
I still do not understand this energy non-conservation issue here. What comes in is what goes out, minus the "toll" that one has to pay to get out. Where is the non-conservation part?
Zz.
Likes mfb and Lord Jestocost
I see. So somehow it is necessarily true that the electric field from the conductor's new positive charge will drain the kinetic energy of the photoelectron before that positive charge can distribute around the inner surface of the shell. Interesting.
Actually, now that I think about it, I guess the the reason why the charge wouldn't distribute first is because it itself is attracted to the photoelectron that was just ejected, so it will want to stay at the point closest to the photoelectron, and if it does that, then the photoelectron doesn't get to escape as it would if there were an even charge distribution.
Sorry! Especially disregard that sequence divergence statement. I realized afterwards it's incorrect in many different ways. Probably should have it deleted so it doesn't confuse everybody who comes across this thread...
Right. I just blindly applied the electrostatics concept of charge distribution as if it happens instantaneously. I see now that that can't apply if there is a floating charge (the photoelectron) inside the shell because the charge on the shell will stay at the point closest to the photoelectron due to mutual attraction, pulling the photoelectron back unless the photoelectron does actually have enough kinetic energy to overcome that pull, i.e., φ > Efin, implying that energy is conserved.
True. I see this now that my definition of φ has been corrected.
Agreed. I'm aware that energy non-conservation is equivalent to saying you can get more than 2 out of 1+1. I just couldn't see where the electric energy was coming from at first since I was thinking of φ as W only or sometimes W plus the initial potential rather than W plus the final potential.
Related to Conservation of electrical energy on a conductor
1. What is conservation of electrical energy on a conductor?
Conservation of electrical energy on a conductor refers to the principle that the total amount of energy in a closed electrical circuit remains constant. This means that energy cannot be created or destroyed, but can only be transformed from one form to another.
2. How does conservation of electrical energy apply to conductors?
In a conductor, such as a wire, electrical energy is transferred through the movement of electrons. The conservation of electrical energy ensures that the total amount of energy in the circuit remains the same, even as the energy is transformed from electrical to other forms, such as heat or light.
3. What factors can affect the conservation of electrical energy on a conductor?
The conservation of electrical energy on a conductor can be affected by factors such as the resistance of the conductor, the voltage applied, and the current flowing through the conductor. These factors can affect the amount of energy that is transformed and how efficiently the energy is transferred.
4. How is the conservation of electrical energy related to Ohm's Law?
Ohm's Law states that the current in a circuit is directly proportional to the voltage and inversely proportional to the resistance. This means that as the voltage or resistance changes, the current and therefore the energy transferred will also change. However, the total amount of energy in the circuit will remain constant due to the conservation of electrical energy.
5. Why is the conservation of electrical energy important?
The conservation of electrical energy is important because it allows us to accurately predict and control the behavior of electrical circuits. It also ensures that energy is not wasted and can be efficiently used for various purposes, such as powering devices or generating light. Additionally, understanding the conservation of electrical energy is crucial for developing sustainable and environmentally friendly energy sources.
  • Electromagnetism
  • Electromagnetism
