Conservation of Energy and Momentum Lie
In summary, Conservation of Energy and Momentum "Lie" is a discussion about the laws of conservation of energy and momentum, and how they cannot fully explain the outcomes of the Newtonian demonstrator experiment. While the laws individually hold true, when applied to this specific scenario, they lead to different results, suggesting that there may be a transfer of kinetic energy that is not accounted for. This indicates that the laws, while helpful in solving problems, do not provide a complete understanding of the underlying physics at play.
arbitrator
Each marble on a Newtonian demonstrator has a mass m, and the 1st marble hits the others with a velocity v.
1. Using the law of conservation of momentum - determine the velocities for:
a. Two marbles moving up
b. Three marbles moving up
c. Four marbles moving up
2. Using the law of conservation of energy - show that the scenarios a-c violate this law.
3. Describe the "lie" in stating that these laws apply and can solve problems.
(assume there is no air resistence and that the marbles are perfectly elastic)
Win + PEi + KEi = Wout + PEf + KEf ( KE and PE are kinetic and potential energy respectivley)
m1v1 = m2v2
So far I have worked through numbers 1 and 2, here is an example of my work:
Using conservation of momentum
a) mv1 = mv2 + mv2
mv1 = 2mv2
v1 = 2v2
Using conservation of energy
a) 0.5mv12 = 0.5mv22 + 0.5mv22
0.5mv12 = mv22
mv12 = 2mv22
v12 = 2v22
v1 = (2)1/2v2
Note: because the mass of each marble is the same, I use m for all the masses; because the velocities of the 1st marble and the other marbles are different, I use v with a subscript to indicate which velocity it is
So I've found that when I use each law to find the velocity of the other marbles, I get different results. My task is to find out why and my teacher instructed me to use the internet. Using what I've learned so far won't help, since all we've covered is motion, forces, energy, and momentum.
Well you're off to a good start. The rest of the assignment is totally conceptual. It helps if you say or write out a few statements: "Conservation of momentum is never violated," and "Conservation of energy is never violated." (let's ignore quantum fluctuations for now).
For any situation, both of these laws must be satisfied, not one or the other. In the "http://www.walter-fendt.de/ph14e/ncradle.htm" " demonstration, what is the outcome that will satisfy both laws at the same time?
And what do your mathematical "disagreements" ( in a, b, and c ) say about the possibility of those outcomes?
In the "Newton's Cradle" demonstration, what is the outcome that will satisfy both laws at the same time?
Would these outcomes be the number of marbles that move up when 1 marble hits the series of marbles? In that case the outcome would be 1 marble moving up when 1 marble hits the series.
But if we change the problem to say that a marble with a mass of m hits a marble with a mass of 2m. As far as the two laws apply, is this problem the same as the original?
mv1 = 2mv2
v1 = 2v2
0.5mv12 = 0.5*2mv22
mv12 = 2mv22
v12 = 2v22[/SUP
v1 = 21/2v2
The velocities are the same as those calculated in the original problem, but still unequal. I'm not sure if I'm thinking along the right lines, but is there some sort of kinetic energy transfer? So that when using the law of coservation of energy I should instead write it as: KEi = KEf + Wout rather than KEi = KEf because the kinetic energy of the 1st marble and more massive marble is not the same? If so then what is the Wout?
FAQ: Conservation of Energy and Momentum Lie
What is the Law of Conservation of Energy and Momentum?
The Law of Conservation of Energy and Momentum states that energy and momentum cannot be created or destroyed, only transferred or transformed from one form to another. This means that the total amount of energy and momentum in a closed system remains constant over time.
How does the Law of Conservation of Energy and Momentum apply to everyday life?
The Law of Conservation of Energy and Momentum applies to many aspects of everyday life, such as the movement of objects, chemical reactions, and the flow of electricity. It also plays a crucial role in understanding and predicting natural phenomena, such as weather patterns and the behavior of celestial bodies.
What is the difference between energy and momentum?
Energy is a measurement of the ability to do work or produce heat, while momentum is a measurement of the motion of an object. Energy can exist in many forms, such as kinetic, potential, and thermal energy, while momentum is a property of moving objects and is dependent on their mass and velocity.
Are there any exceptions to the Law of Conservation of Energy and Momentum?
The Law of Conservation of Energy and Momentum is a fundamental law of physics and has been proven to hold true in all observed cases. However, in extreme environments such as black holes or during the birth of the universe, it is possible that these laws may not apply in the same way as they do in our everyday experiences.
How is the Law of Conservation of Energy and Momentum related to Newton's Laws of Motion?
The Law of Conservation of Energy and Momentum is closely related to Newton's Laws of Motion. The first law, also known as the Law of Inertia, states that an object will remain at rest or in motion unless acted upon by an external force. This is consistent with the idea that momentum is conserved in a closed system. The second law, which relates force, mass, and acceleration, can be derived from the conservation of momentum. Finally, the third law, which states that for every action, there is an equal and opposite reaction, is also a result of the conservation of momentum.
