Conservation of energy as a function of Time
In summary, the ball falls down a free-fall and we are supposed to use calculus to find its position as a function of time. We derived a conservation of energy equation which we then used to find the ball's initial position.
PlantPage55
A ball of unspecified mass is in a free fall - and we are supposed to rearrange equations to teach us the basics of kinematics. It's a general question with no values given for the variables
Use your conservation of energy equation: v = sqrt(2gh) and calculus to write an expression for the ball's position as a function of time.
It's the last part that is getting me. I'm thinking they want me to use an integral to find the position-time graph or something. Alternatively, I can't figure out how to relate a kinematic equation: y=(1/2)gt^2 (in this case) to the conservation of energy equation we derived.
(We derived this conservation of energy equation from putting the kinetic energy in terms of its velocity - then relating this energy transfer to the force of gravity working on this free falling ball. The result was the above equation - which is supposed to be an equation of velocity in terms of the forces acting on the ball. Did I do that right?
3. Attempt at Solution
I've been bothered by this for hours. I tried writing the integral of the v = sqrt(2gh) function, but I just get a messy integral and I'm not sure that's the right idea anyway. Maybe I'm misinterpreting the question?
Thanks for any help you can give!
Okay let's write v = sqrt(2gh), in calculus terms
[tex]\frac{dy}{dt} = \sqrt{2gy(t)[/tex]
Or
[tex]\frac{dy}{\sqrt{2gy(t)}} = dt[/tex]
Or if you integrate both sides
[tex]\int{\frac{dy}{\sqrt{2gy(t)}}} = \int{dt} = t + C[/tex]This is an easy enough integral, then solve for y(t) and use your initial conditions to find C.
Try using
[tex]v = \frac{dy}{dt}[/tex]
and
[tex]y(t)=h_o - h(t)[/tex]
y positive downwards.
Excellent! Thank you - that makes great sense!
FAQ: Conservation of energy as a function of Time
What is conservation of energy as a function of time?
Conservation of energy as a function of time is a fundamental principle in physics which states that the total energy in a closed system remains constant over time. This means that energy can neither be created nor destroyed, but can only be transferred or converted from one form to another.
How does conservation of energy apply to real-world situations?
Conservation of energy applies to all physical processes, including those in the real world. For example, the energy from the sun is converted into heat and light energy on Earth, and then plants use that energy to grow through photosynthesis. This is just one example of how energy is conserved in everyday life.
What is the role of time in conservation of energy?
Time is an important factor in conservation of energy as it determines the rate at which energy is transferred or converted. When energy is transferred from one form to another, it takes a certain amount of time for that process to occur. Time also plays a role in measuring energy, as energy is often expressed in units of joules per second (or watts).
How does the concept of entropy relate to conservation of energy as a function of time?
Entropy is a measure of the disorder or randomness in a system. When energy is transformed or transferred, it often results in an increase in entropy. However, the total energy in a closed system remains constant over time, even as entropy increases. This is because energy can be converted into a less organized form, but it is still conserved.
What are some potential consequences of not following conservation of energy as a function of time?
Not following conservation of energy as a function of time can lead to major consequences in the natural world. For example, if energy is not conserved, it could lead to an imbalance in ecosystems and cause disruptions in the food chain. In human society, not conserving energy can result in depletion of resources and increased pollution, which can have long-lasting and detrimental effects on the environment.
